ᐅ How can I optimize storage space in IKEA Metod base cabinets using organizational systems?
Created on: 17 Jan 2021 08:47
fularenHello everyone!
I have a somewhat specific question and hope to find helpful tips here in the forum: How can I optimize storage space in IKEA Metod base cabinets using organizational systems?
Specifically, I own several Metod base cabinets that I’d like to organize better. It’s important for me to use as much space efficiently as possible without having to empty everything each time I want to access items at the front.
So far, I’ve only used IKEA’s built-in drawer inserts and cutlery trays in a basic way, but I believe there are much smarter or more flexible systems available, possibly including combinations with third-party products.
Key factors for me are adjustable heights and wide compartments, easy access, and ideally modular systems so I can rearrange as needed.
Does anyone have practical experience with organizational systems or clever tips that work well inside Metod base cabinets?
I look forward to your tried-and-tested recommendations!
Marlenepa17 Jan 2021 09:36Hello fularen,
First of all, I think it’s great that you asked your question in such detail, as this makes it much easier to provide helpful answers.
To optimize the storage space in IKEA Metod base cabinets, I recommend keeping the following points in mind:
- Use height-adjustable shelves inside; these allow you to make better use of vertical space and adapt flexibly to containers of different heights.
- Stackable organizer boxes are ideal for dividing large cabinet interiors, especially if you are storing smaller items.
- For drawers, you can also get partition systems made of plastic or wood, such as adjustable inserts that can be adapted to the width of the respective drawer.
- IKEA now also offers metal rod organizers and removable inserts for spices or bags – these can be combined well to keep various items clearly separated.
- If you decide to go with third-party products, I recommend systems that are precisely sized for the Metod dimensions, such as modular telescopic organizers that fill the cabinet space optimally without wasting room.
A small tip: When organizing, place frequently used items in the upper or more easily accessible drawers and less often needed items lower down. This way, you can avoid having to constantly rearrange everything.
If you like, I can provide some links to examples or go into more detail about specific cabinet types.
I use the IKEA interior organization system for Metod cabinets, mainly the cutlery trays and small boxes for miscellaneous items.
In the large base cabinets, a pull-out basket or a coated metal bar for stacking pots also works very well.
Always pay attention to the internal dimensions and avoid choosing inserts that are too tall, so the drawers can close properly.
edisondan18 Jan 2021 14:03For clarification:
From a mechanical perspective, Metod base cabinets offer an internal height of approximately 80 cm (31.5 inches) with a width of 60 cm (23.6 inches), depending on the model. Since a large portion of the storage space is divided by drawers, choosing inserts with adjustable heights is essential to make the most efficient use of the available space.
I recommend using modular divider systems that can be adjusted both horizontally and vertically. This allows drawers to be divided into sections, keeping smaller items organized and visible.
Additionally, pull-out trays or baskets behind the front panel significantly improve access to items stored deeper inside.
In practice, combining original IKEA accessories (such as VARIERA inserts) with high-quality, precisely fitting third-party systems (for example, made of metal or bamboo) usually results in the best balance of functionality and durability.
Key points summarized:
- Adjustable dividers for flexible layout
- Pull-out baskets for better accessibility
- Full use of internal cabinet height
- Material quality for longevity
This approach ensures cabinets are organized sustainably and comfortably.
Marlenepa schrieb:
When organizing, make sure to place frequently used items in the upper or more easily accessible drawers, and less frequently needed ones further down.I want to emphasize this point, as it is often the key factor in practice that helps maintain order and saves time.
Another improvement is the use of labels on inserts or the inside of drawer fronts. This way, even with many small compartments, you can keep track without long searches.
Additionally, a mix of transparent and opaque boxes can be useful: transparent ones provide immediate visibility, while opaque ones protect against dust and create a calm overall appearance.
In summary: structure and clarity significantly enhance the usability of storage solutions.
