Hello everyone, I am currently planning to reorganize my Ikea Pax wardrobes and want to securely install the hanging rods. My specific question is: What is the best way to fix the hanging rods in Ikea Pax so that they are both highly load-bearing and easy to install, while also allowing for flexible positioning if needed? I have seen that Pax offers different types of mounting options, such as hanging rod brackets with or without additional reinforcements. What should I pay particular attention to? Are there any special tips to prevent the rods from sagging or even pulling out? I am also interested in whether it makes sense to install additional anchors or reinforcements inside the cabinet. Perhaps someone here has practical experience, tips on tools, load limits, or effective installation practices? I look forward to your advice.
For optimal fastening of the clothes rods in the Ikea Pax system, there are a few important points to consider. Ikea typically uses holders for the clothes rods that hook into pre-drilled holes in the side panel. The load capacity depends on the correct hooking as well as the condition of the panel material.
- For safety, I recommend making sure the clothes rod is properly seated on the designated holders and not just loosely placed.
- For higher loads, additional wall brackets can be used, provided the Pax wardrobe is mounted directly to the wall.
- Using original replacement fittings is important because third-party products often do not fit well and are less stable.
What many do not know: the positioning within the hole pattern of the Pax system is designed with a precise 32 mm (1.26 inches) spacing, which offers a lot of flexibility but also means that heavy loads can be problematic without additional reinforcement. Dowels in the cabinet body are usually not necessary, as the system is designed for the intended use.
To explore the question in more detail, the Pax construction should be examined technically. The clothes rods are usually made of metal with a diameter of about 22 to 25 mm (0.9 to 1 inch) and are hung into so-called "clothes rod brackets." These brackets, made of plastic or metal, are attached to the side panels, which consist of chipboard material with a thickness of 5 mm (0.2 inches).
Here are some more specific details:
- Load capacity: The maximum load of the clothes rod is usually stated as 30 to 40 kg (66 to 88 lbs), depending on the design.
- To prevent sagging, the installation of a center support has proven effective, especially for wide Pax wardrobes over 100 cm (39 inches) in width.
- The brackets must be installed level at the wardrobe height; otherwise, the rods can slip out of their guides.
- It is also important to screw in very carefully and only precisely into the designated drilled holes, as the material can otherwise tear out.
My recommendation: If it is a wide wardrobe variant, definitely install an additional center support and, for heavy clothing, opt for metal brackets instead of plastic ones.
Have you ever tried pre-fixing the brackets by drilling small pilot holes into the side panels, or do you have special load requirements?
warrenka5724 Aug 2024 08:22Filippo schrieb:
To explore the question in more depth, the Pax system should be considered from a technical perspective.I can fully understand how important this topic is to you—I had similar thoughts when organizing my wardrobes. What really helped me was first carefully assessing how much load the rods actually need to support. In my case, I have to hang many heavy winter coats, so I added an extra center support bracket.
Maria35 schrieb:
Using original replacement fittings is important because third-party products often don’t fit optimally and are less stable.I can only confirm that. I tried using cheaper brackets but ended up removing them right away because they didn’t hold properly, which made installation more complicated.
If you need a lot of variation: I recommend installing the brackets in the pre-drilled hole rows and testing the setup with a trial installation before the final mounting. Altering the system afterward costs a lot of time and patience. Feel free to ask if a specific load case or room height causes problems!
Hello Laufi, it is important to also check the quality of your tools. For attaching the closet rods in the Pax system, it is best to use a cordless screwdriver with a torque limiter. This prevents over-tightening the screws and protects the particleboard.
I recommend the following approach for installation:
- First, position the brackets and secure them lightly.
- Insert the rod temporarily and check that everything is level.
- Then fully tighten the screws without over-tightening.
- For wider cabinets: attach the middle bracket at the height of the side panels.
If you prefer flexible solutions that allow you to frequently reposition the rods, I suggest using the pre-drilled holes to avoid weakening the cabinet carcass.
If you want to reduce the weight load from the rod on the cabinet frame, it can help to additionally stabilize the cabinet when mounting it on the wall – for example, by reinforcing the back panel. This reduces twisting and ensures reliable support.
Best way to install clothes rails in Pax wardrobes:
- Use the original clothes rail brackets
- Hang them into the pre-drilled holes on the side panels
- For wider wardrobes, install a center support
- Never fix the rail without a bracket
- Do not overtighten screws (chipboard can split)
You can achieve more flexibility with the 32mm (1.26 inch) system of Pax. For heavy loads, always use metal brackets.
