ᐅ How can I install Ikea Metod cabinets efficiently in limited space?
Created on: 16 Nov 2024 08:17
Na_pu
Hello everyone, I’m planning to install some Ikea Metod kitchen cabinets in my small apartment, but I have very limited space available. So my question is: How can I set up Ikea Metod cabinets in a small area in the best way to maximize storage, ensure the cabinets are stable, and lose as little movement space as possible? I’ve seen that the modules are flexible, but I’m a bit confused about the dimensions, especially when it comes to combining tall units with base cabinets or wall cabinets. Are there any universal tips or tricks to keep the setup compact yet functional, without causing obstruction later on? Looking forward to your experiences and advice!
Palenar schrieb:
What does your room look like? Do you have any special niches or sloped ceilings? That also determines the best choice of modules.Thanks for the detailed tips! Yes, I actually have a small L-shaped kitchen corner with about 180 cm (70 inches) on the short side and 240 cm (95 inches) on the longer side, plus just a few centimeters of clearance to a balcony door. The ceiling height is 2.40 m (7 ft 10 in), with no sloped ceilings. The floor is level. I noticed you recommend tall units, but I’m not sure they make sense near the balcony door since that’s where the passage is. So, I’m considering using only base cabinets and wall cabinets there. The question is how to arrange everything so it doesn’t feel cramped and all doors can be fully opened. Does anyone have experience or concrete planning ideas for this?
Na_pu schrieb:
The question is how to arrange everything so that it doesn't feel too cramped and all doors can be opened easily.In your case, it makes sense to place the tall units along the longer wall – they will be less in the way there. For the side with the balcony door, I recommend shallow base cabinets with a depth of no more than 40-50 cm (16-20 inches) to keep the walkway clear. Wall cabinets above can be kept narrow as well (for example, 20-30 cm (8-12 inches) deep). Pay special attention to ensuring cabinet doors and drawers do not protrude into the walkway, as this can make the space feel and actually be more cramped.
If the balcony door opening is right next to the kitchen run, sliding doors or flush cabinet fronts can help improve functionality. I have often noticed that it is worth not extending wall cabinets along the entire length but planning their dimensions precisely so that the kitchen feels open and airy.
Jensson schrieb:
For the side with the balcony door, I recommend shallow base cabinets with a depth of 40-50 cm (16-20 inches) max to keep the walkway clear.Exactly. A small note from me: if the floor is level, make sure the cabinets are precisely aligned – otherwise, doors may be difficult to open. Also helpful: use drawers instead of doors for base cabinets in tight spaces. Drawers pull straight out but require less side clearance to open.
Additionally, at Ikea you can choose extra soft-close hinges, which make operating cabinets in compact areas more comfortable. For maximum space utilization, internal drawers that extend deep into the cabinet help keep things organized.
Here’s a practical tip: Make sure to check how the balcony door opens – does it swing inward or outward? If it opens inward into the passage, nothing should block it. If it opens outward, you have more freedom! The placement of tall cabinets largely depends on whether you still need enough clearance space. A depth of 60 cm (24 inches) for base cabinets is often too large for small rooms, so be sure to check this carefully in advance.
By the way, a smart solution for small spaces is cabinets with full-extension drawers – they offer better visibility and fewer tripping hazards compared to deep traditional base cabinets with doors.
Feel free to ask again if you want to specify exactly where your main work area will be, so we can plan it in more detail.
warrenka5718 Nov 2024 08:15I completely understand that concerns about space and tightness can be stressful for you. You want an efficient kitchen without constantly feeling cramped. From my experience, even small kitchens don’t have to compromise on comfort. My advice: take your time when setting it up, and if possible, plan for extra surfaces that can fold down or slide out—like a small rolling shelf or a pull-out pantry cabinet.
Last but not least: appearance matters a lot! Light-colored fronts and clean lines visually increase the sense of space. Keeping the workspace clear also helps make the tightness more manageable. Stay focused and maintain a balance between functionality and room to move.
Kinbu schrieb:
Feel free to ask again if you want to specify exactly where your main work area should be so we can plan it in more detail.Good question. I would place the sink on the short wall, ideally centered. The stove would go on the longer wall at the edge, leaving enough countertop space between the sink and stove. I want the workspace to be as compact as possible since there isn’t much room. So rather short surfaces, but easily accessible. For the tall unit, I was thinking of the corner if that makes sense. Your tips are really helpful!
