ᐅ How can I best install IKEA Metod cabinets in loft apartments?
Created on: 6 Mar 2021 14:23
Sopra53
Sopra53
6 Mar 2021 14:23
Hello everyone, I am facing the challenge of fitting IKEA Metod kitchens or cabinets optimally in my new loft apartment. The ceilings are very high, the spaces are open, and there are hardly any traditional walls or niches. My specific question is: What strategies or installation methods can I use to integrate the Metod cabinets not only securely but also attractively in such loft-style spaces? I am especially interested in how to handle the height, whether it is advisable to install cabinets freestanding, as room dividers, or attached to certain walls. Are there also tips on adjusting cabinet height, using shelving, or lighting for the best spatial effect? I look forward to your experiences and well-founded advice!
Gere5
6 Mar 2021 15:11
I recommend always anchoring the Metod cabinets to solid walls, even in lofts. Regarding the height: hang the upper cabinets, and tall base cabinets can be used as room dividers. Freestanding cabinets are unstable and usually do not fit well.
Alberto51
6 Mar 2021 16:37
I find your question really interesting because loft apartments often present unique challenges. I spent a long time thinking about how to best position my Metod cabinets. At first, I wasn’t sure whether to boldly use tall cabinets, since large open areas can quickly feel overwhelming.
Gere5 schrieb:
Freestanding cabinets are unstable and usually don’t fit well.
That’s true—I noticed that right away and would also recommend using walls as anchors instead. Another thing I’ve learned: installing lighting inside the cabinets adds a lot of atmosphere, especially with open shelves or glass display units. It helps to break up the often cold appearance.
I completely understand your desire for both stability and aesthetics—don’t hesitate to make personal adjustments, it definitely pays off!
Dopoki
7 Mar 2021 09:42
For the optimal installation of IKEA Metod cabinets in loft apartments, a systematic approach is recommended. First of all, the modules are designed for wall mounting and require a secure attachment. In loft apartments with large, often load-bearing walls, installing the cabinets on these walls is advisable, as this ensures maximum stability.
For the height, I recommend choosing the maximum cabinet depth and height so that they are proportional to the room. Metod components typically come in a depth of 60 cm (24 inches); for open lofts, a shallower depth (e.g., 37 cm (14.5 inches)) can be considered to avoid overwhelming the space.
The idea of room dividers is practical but requires additional stabilization, for example, through floor anchoring.
From a technical perspective, lighting is useful: LED strips inside the cabinets or under shelves noticeably improve both functionality and visual appeal.
In conclusion: IKEA’s installation manuals are detailed, and their mounting systems can be supplemented with additional profiles or custom brackets if standard walls are not available.
Garry
7 Mar 2021 12:58
In lofts, it is especially important to consider structural stability and efficient use of space. IKEA Metod cabinets should never be used freestanding without additional anchoring, as their construction is not designed for this.
I recommend mounting cabinets on load-bearing walls. If this is not possible, tension rods between floor and ceiling or special mounting rails can be used.
To visually integrate the cabinets into the loft, open shelving and varied fronts should be used to emphasize the industrial character.
The ceiling height can also be well utilized by installing tall cabinets with appropriate panels. This creates a clean line and adds storage space without producing a modular, boxy appearance.
