PaKatharin4 Jan 2022 08:37Hello everyone,
I am planning to assemble a desk from the Ikea Hemnes series but have concerns about how to build it optimally for stability and durability. I am particularly interested in:
- Are there any specific tips or assembly sequences that improve stability?
- What is the best approach to installing the drawers to ensure they open smoothly?
- Which tools are best suited, and is the included hardware really sufficient?
- Does anyone have experience handling the back panels, which often help increase stability?
I want to avoid mistakes that could later make the desk unstable or cause the drawers to jam. I would appreciate detailed advice and tips!
Hello PaKatharin,
your questions about the optimal assembly of the Ikea HEMNES desk are well formulated and can be answered systematically.
- Order: Always start with the side panels and back panels, as they provide the basic stability. Then assemble the drawers before attaching the desktop.
- Drawers: Make sure to install the rails exactly straight and parallel. Using a spirit level is ideal for this.
- Tools: The supplied Allen key is usually sufficient, but a cordless drill with torque control makes the work much easier and faster without over-tightening the screws.
- Back panels: These must be installed without tension and perfectly straight. They significantly stabilize the desk and prevent warping.
Additionally, I recommend tightening all screws by hand first and only fully tightening them at the end to compensate for any inaccuracies.
If you have any further questions about assembly, feel free to ask.
sarGabriel4 Jan 2022 10:05Joshbe schrieb:
Always start with the side panels and back wallsExactly. Also, install the drawers only after completing the basic framework.
Hello PaKatharin,
I would like to add something: Patience is especially important when working on the back panels. It’s best to use a smooth surface when fastening the back panel with nails to prevent any warping.
When assembling the drawers, make sure the rollers or slides click into place properly – this is crucial for smooth operation.
If you’re unsure, use cotton gloves to avoid scratches on the surface when joining the tabletops and side panels.
Last but not least – if the floor isn’t completely level: washers or felt pads under the feet can help prevent wobbling.
I hope these tips are helpful!
PaKatharin schrieb:
Which tools are best suited, and is the supplied material really enough?The included materials are generally sufficient for assembly, but the quality of the construction largely depends on correct usage. I strongly recommend getting a small cordless screwdriver with torque control. This helps prevent over-tightening and damaging screws and wooden panels.
Additionally, you should have a small hammer ready for the back panel nails and a spirit level to check alignment.
These three tools will make the assembly easier, ensure quality, and help you build the desk optimally and securely.
