ᐅ How do I install Ikea Metod wall cabinets on drywall (plasterboard)?
Created on: 26 Dec 2021 08:37
Maunon
Hello everyone, I am currently facing the challenge of mounting Ikea Metod wall cabinets on a drywall partition. My wall is a standard double-sided gypsum board stud wall without any visible wooden framework at the mounting height.
I am mainly interested in how to securely fasten the wall cabinets so that they can support the full weight of both the cabinets and their contents without damaging the drywall or causing the fixings to fail. Which types of anchors are best suited for this? Are metal anchors enough, or are special cavity anchors necessary?
I would also like to know the best way to distribute the load and whether it makes sense to install additional reinforcements inside the wall.
Thanks in advance for any tips or sharing of experiences!
Paunon
27 Dec 2021 10:18
I also mounted the Metod wall cabinets on metal studs at my place – this worked smoothly using special metal anchors. It is important that the drill bit is suitable for metal profiles to ensure the anchors fit securely.
Maunon
28 Dec 2021 11:43
Thanks for the helpful feedback. To summarize:
- Please do not mount Metod wall cabinets using only standard drywall anchors.
- Metal or wooden studs behind drywall provide the best mounting support.
- Use specialized anchors designed for metal studs.
- Distribute the load across multiple fastening points.
My last question: Are there any specific anchor products you recommend for mounting on metal studs? Or a maximum load per anchor that should not be exceeded?
Thank you very much!
