Hello everyone, I want to modify our IKEA Malm furniture to be more child-friendly since my child is becoming mobile and I have some safety concerns. Specifically, I’m interested in how to adjust drawers and doors to make them safer for small children—such as using child locks, edge protectors, or other safety measures. At the same time, I want to maintain the furniture’s appearance as much as possible and avoid reducing stability or making the furniture harder to use. Does anyone have experience with these kinds of modifications? Which materials and tools work best? And are there tried-and-true methods or helpful tips to prevent injuries like pinching or sharp edges? Thank you very much for any advice!
Hello Moismet,
The main issue with Malm furniture is often that small children can pull out the drawers, which may cause the unit to tip over. Therefore, I recommend first securing the furniture firmly to the wall using anti-tip brackets or corner braces.
I completely agree with this. Magnetic or clamp locks that are installed inside the furniture are also a good option. The advantage is that adults can easily open them, but for children they are often quite tricky.
Additionally, I recommend sealing all sharp edges with PVC corner protectors, which are transparent and hardly noticeable. It is important to check the dimensions of the drawers and doors when purchasing these, as some protection systems are not universally compatible.
I am curious: How many pieces of furniture do you want to modify, and are they mainly drawer dressers or also wardrobes? That could influence the choice of safety devices.
NOELIAGA schrieb:
The most important thing is lockable child safety devices for drawers and doors.
Thank you for the helpful advice, especially regarding wall mounting; I will definitely address that.
Essentially, these are two Malm chests of drawers, each with three drawers, and a small wardrobe with doors. I’m particularly unsure whether I should install additional drawer guides or dampers to prevent the drawers from being pulled out or slammed quickly. Has anyone had experience with retrofit kits like these—do they work reliably or tend to cause issues?
Another concern I have is mounting magnetic locks: How well do they hold on Malm furniture, which has relatively thin wood? Is standard screw mounting sufficient, or are special anchors recommended?
reybo schrieb:
I’m curious: How many pieces of furniture do you want to modify, and are they mainly drawer chests or also wardrobes?
Magnetic catches work well as long as they are installed correctly. Since Malm furniture is often made from particleboard covered with a thin veneer, I strongly recommend using anchors or at least pre-drilled holes with screws to avoid damaging the material.
Regarding the guide rails: For children who tend to pull drawers quickly, dampers or soft-close mechanisms can help reduce slamming. However, these retrofit options can sometimes be somewhat complicated to install and may not always fit perfectly. Especially if you want to keep the original appearance, I suggest carefully checking the measurements before purchasing.
I also find it important that the furniture is secured to the wall, as this is the best protection against tipping when dealing with active toddlers.
If you like, I can send you a list of suitable child safety products that have proven effective for Malm furniture.
