ᐅ How can I modify an Ikea Besta unit to ensure it is well-ventilated when used as a shoe cabinet?
Created on: 24 Jan 2024 08:34
IONUTTARHello everyone, I am currently planning to modify my Ikea Besta cabinet to make it well-ventilated for use as a shoe cabinet.
The goal is to prevent my shoes, especially sports shoes, from becoming musty or suffering from trapped moisture. I am thinking of a combination of air circulation and moisture management. My Besta is about 60 cm (24 inches) high, 60 cm (24 inches) wide, and 40 cm (16 inches) deep, with closed doors.
My questions are:
- How can I effectively increase air exchange without completely compromising stability or appearance?
- Are there practical methods, such as ventilation slots, grille inserts, or even small fans?
- What should I consider in terms of materials and craftsmanship when drilling holes or openings in the wood?
- Does anyone have experience with passive ventilation systems for similar furniture?
I would appreciate concrete, practical tips that are not too complicated or expensive. Thank you!
My questions are:
narDietmar24 Jan 2024 11:07Hello IONUTTAR,
to effectively ventilate the Besta as a shoe cabinet, I recommend a combined approach:
- First, it is important to add air vents at strategic locations, such as on the back panel or at the bottom of the furniture. Usually, drilling ventilation holes with a Forstner bit or installing a grille is sufficient to allow airflow.
- You should modify the material only in inconspicuous areas to maintain stability and appearance. Make sure to deburr the edges carefully to prevent moisture from entering.
- Additionally, you can use removable shelves made from breathable material inside or employ small fans powered by electrical outlets to improve air circulation—though these are more of a luxury option.
- Otherwise, it is helpful to let shoes dry before placing them in the cabinet and to use moisture-absorbing inserts like activated charcoal or silica gel.
If you are interested, I can also provide a sketch showing the optimal locations for the ventilation holes.
narDietmar schrieb:
To properly ventilate the Besta used as a shoe cabinet, I recommend a combined approachVentilation slots at the bottom and top are sufficient.
Do not overfill the shoe compartments.
Air out regularly and take the shoes outside.
I would even go one step further: if you like, you can make or buy very lightweight lattice doors as fronts and simply use the standard fronts as sliding doors, so air can flow in and out at any time!
This works great with lattice doors – the look stays modern, and the ventilation is excellent.
Also, simple ventilation grilles in the back panel from the inside create a good draft, especially if you have a lattice door in front. A small battery-powered fan system inside? Awesome if you’re into technology!
Better to put in a bit of effort than end up with smelly shoes. I did it myself this way, and it works perfectly!
bauku schrieb:
I would take it a step further: if you like, you can craft or buy very lightweight lattice doors as fronts and simply use the standard fronts as sliding doors Very good suggestion.
To add: when remodeling, it is important to pay attention to material moisture and ventilation cross-section.
I would ensure that at least 5–10% of the front surface area is available as ventilation space to prevent moisture buildup.
A simple and reliable method is using perforated back panels made of thin plywood with ventilation holes, possibly combined with air cushion or plastic grids to improve stability.
If you choose to use fans, make sure they operate quietly and consume little power.
One small additional tip: try to avoid storing shoes directly against the cabinet wall; instead, use lightweight shelves with some spacing – this significantly improves air circulation.
