ᐅ How can I modify an IKEA Besta unit to function effectively as a well-ventilated shoe cabinet?
Created on: 5 Jun 2020 08:37
Julu6Hello everyone, I am planning to modify an IKEA Besta cabinet to use it as a shoe cabinet, ensuring it is well ventilated to prevent moisture problems and odors. My idea is to integrate ventilation holes or grille elements, and possibly install ventilation slots in the back panel or sides. However, I’m unsure how to do this in the best way without compromising the stability of the furniture or ruining the appearance. Does anyone have experience or know effective solutions for converting a Besta cabinet so that shoes can be stored optimally without causing bad smells or mold? Any advice on materials or practical tips for the conversion would also be very helpful. Thanks in advance!
For ventilating an IKEA Besta used as a shoe cabinet, the following points should be considered: - Remove parts of the back panel or drill small ventilation holes, at least 3-5 cm (1¼-2 inches) in size and grouped together. - Install ventilation grilles on the inside of the doors, preferably at the top and bottom. - For additional air exchange, it is advisable not to fully seal the back panel but to replace it with perforated material, for example. - Use plastic ventilation grilles to prevent rust. This ensures constant air circulation and minimizes moisture buildup.
Celia schrieb:
I would recommend cutting air vents into the back panel and covering them with fine mesh.That sounds very reasonable, but does anyone have an idea of the best way to do this without damaging the MDF board? I was thinking of drilling many small holes first and then connecting the vents with a jigsaw. Would that work, or is there a better method?
Rodolfo schrieb:
For additional airflow, it makes sense not to fully seal the back panel, but to replace it, for example, with perforated material.Is it possible to completely replace the back panel? Or would that compromise the structural stability?
Julu6 schrieb:
Is it possible to completely replace the back panel? Or would that compromise stability?Replacing it is feasible, but you should ensure that the replacement panel is at least the same thickness. The main stability comes from the side walls and the frame. The back panel mainly provides bracing, so you should secure the new back panel well and reinforce it if the original panel is being replaced with a perforated one.
