Some time ago, I bought a Malm bed from IKEA and use it for a child. I noticed that while the design is quite simple and clean, the construction feels not very sturdy due to the relatively thin material and the basic joinery techniques.
My question is: How can I make MALM furniture, especially beds and dressers, more stable? Are there proven methods to reinforce the connections or accessories that fit well without significantly altering the design?
I am particularly interested in strong and durable solutions, as the furniture is used daily and the weight occasionally varies. Thanks in advance for your tips and experiences!
lisla schrieb:
the MALM standard bed (140x200cm (55x79 inches)), where the corner joints between the headboard/footboard and the side panels are not really secureThis makes me wonder: Why choose Malm at all?
The design of this series is intentionally simple and produced cheaply, with little focus on durability.
If you want a solid bed, it often requires stronger materials or a complete rebuild with a custom frame. All the tricks with brackets and dowels are more like temporary fixes.
Building your own reinforced frame from wood or metal underneath, using the MALM dresser solely as storage, would in my opinion be a more elegant and safer long-term solution.
But if you still want to make MALM stable, you should critically question the construction and not try to save more than is possible with clips.
Simply put, the MALM frame is made from veneered particleboard, which is not designed for maximum load capacity. If you want to improve stability, as mentioned before, you should:
- Install metal brackets at internal joints
- Add longitudinal supports under the slatted frame
- Reinforce fastening points with wood glue and wooden dowels (if the frame is not frequently disassembled)
These are proven measures that work well in practice. The design is only minimally affected if the brackets are placed carefully.
However, retrofitting without modifying the base material will only achieve limited success.
Lamar schrieb:
If you want a sturdy bed, you often need stronger materials or a complete rebuild with your own frame.That’s true, but honestly, sometimes a bit of extra reinforcement is enough to stop the bed from wobbling or squeaking.
My advice: upgrade the substructure slightly—either with solid wooden slats or metal braces—and that often extends its life by several years.
And yes, clean metal brackets inside the corners have also become real heroes of furniture durability for me 😎.
