ᐅ How can I install Ikea HEMNES cabinets to make them especially user-friendly?
Created on: 17 Mar 2019 08:43
akim-gla
akim-gla
17 Mar 2019 08:43
Hello everyone, I’m looking for tips and experiences on how to assemble Ikea Hemnes cabinets in a way that is especially user-friendly. I am particularly interested in how to organize the assembly so that later handling—such as opening, closing, and access to the interior—is as comfortable and durable as possible. Are there any recommended adjustments to the assembly, for example in the order of installing individual components, or suitable modifications to doors, drawers, and hardware that make daily use easier? Any advice on reinforcements or changes to the original parts that improve handling is also very welcome. Thanks in advance for your suggestions!
TEBILO
17 Mar 2019 10:19
To improve the ease of assembly for the Ikea HEMNES cabinets, I recommend dividing the process into several well-planned phases. First, carefully inspect all individual parts — check the wooden components for damage and accuracy of dimensions, and test the fittings for proper function. I suggest attaching the doors directly to the hinges during assembly. It is best to use Ikea’s adjustable hinges, as they allow fine-tuning and ensure long-lasting precise alignment.
To enhance user convenience, you might also consider retrofitting the doors with so-called “soft-close” mechanisms. These reduce noise and help protect the wood during frequent use.
Another important point is to level the cabinet frame using a spirit level and, if necessary, shims to prevent it from being skewed. A cabinet that is not standing perfectly upright significantly complicates operation.
Additionally, if your unit has drawers, I would treat the drawer slides with some silicone spray. This will make opening and closing much smoother.
One question for you: What size is your HEMNES cabinet and what is its intended use? This influences possible optimization options.
bijo54
17 Mar 2019 14:07
What often helps with HEMNES is to adjust the cabinet doors slightly before fastening them to avoid sticking. Also, be sure to check the plastic glider softeners – sometimes it’s worth upgrading to higher-quality furniture gliders for smoother operation.
tolokau
18 Mar 2019 09:36
Below is a brief guide for assembling Ikea HEMNES cabinets with user-friendliness in mind, reflecting my personal experience:
- Preparation: Check all parts for completeness and damage, especially hinges and screws.
- Assemble the carcass: Use a spirit level for precise alignment and shims to ensure the cabinet stands straight even on slightly uneven floors.
- Install doors: Retrofit with soft-close fittings or precisely adjust the original adjustable hinges to minimize future adjustments.
- Drawers: Apply an appropriate lubricant to the rails to ensure smooth operation and increase durability.
- Handles: Consider replacing standard handles with more ergonomic options if the original ones are very small or uncomfortable.
It is important to work carefully at every step and avoid overtightening screws to prevent weakening the material. If possible, working with two people can help: one holds and aligns while the other tightens screws.
The result is a cabinet that operates smoothly, remains reliable over time, and requires minimal follow-up adjustments.
