ᐅ How can I make IKEA BESTA drawers easier to operate and quieter?
Created on: 28 Jul 2024 08:47
leocole
leocole
28 Jul 2024 08:47
I own several IKEA Besta drawers and have noticed that they often operate roughly and are relatively noisy when opening and closing. Especially the initial movement sometimes feels a bit stiff, and the noise can be annoying, particularly in quiet moments. My question is: How can I improve the usability of the IKEA Besta drawers so that they open more smoothly and quietly?
I am looking for practical solutions that can be done with minimal effort, preferably without complicated modifications or expensive replacement parts. If anyone has experience with specific maintenance products, lubricants, or replacing the drawer slides, I would be especially grateful for any advice.
Looking forward to your tips and suggestions!
Jensson
28 Jul 2024 10:15
Hello leocole,
to make your IKEA BESTA drawers operate more smoothly and quietly, there are some proven steps you can follow. Here is a brief guide to help you proceed systematically:
- First, remove the drawers completely from the cabinet. This makes it easier to clean and inspect the drawer slides.
- Next, clean the drawer slides thoroughly. Metal or plastic particles, dust, and dirt are common causes of sticking and loud noises.
- After that, I recommend lubricating the slides with a suitable lubricant, such as a silicone-based spray. Note: WD-40 is a popular product but is more of a cleaner than a lubricant and is less suitable for long-term lubrication.
- If the drawer slides are damaged or show significant wear, it is worth replacing them. IKEA sells compatible replacement parts for BESTA systems.
- Finally, you can also check the glides on the underside of the drawers. Sometimes replacing or renewing these can help improve movement and reduce noise.
If you like, I can also provide a list of recommended lubricants and where to find them.
In my experience, these steps are the best way to noticeably improve operation while reducing noise.
benon
28 Jul 2024 12:02
Hello leocole,
I would like to add some information about possible reasons for the somewhat stiff operation and explain why the drawers sometimes make noise:
- IKEA BESTÅ drawers usually have metal runners with plastic components. These can develop rough spots due to dust, small dirt particles, and wear.
- If the lubricant is missing or has become sticky, this increases friction, which in turn requires more force and causes noise.
- Additionally, drawers can be stressed by overloading or uneven weight distribution, which puts strain on the glides and slows down the mechanism.
Therefore, I recommend:
- Thorough cleaning, as Jensson already mentioned.
- Avoid using oil-based lubricants, as they attract dirt. Dry lubricants (e.g., PTFE spray) are better.
- If necessary, also check the installation position—very tight fitting drawers can also cause higher resistance.
By following these steps, your drawers will not only operate more smoothly but also significantly quieter.
Gloriagl10
29 Jul 2024 07:36
Clean the tracks thoroughly and use a silicone-based spray for lubrication. This usually reduces noise and allows smoother movement. If that is not enough, used dampers might help to soften the closing motion.
Nabla64
29 Jul 2024 09:51
leocole schrieb:
Especially the initial movement sometimes feels a bit stiff, and the noise is annoying
This is exactly where my experience comes in. The “stiff” sensation when opening often results from uneven movement along the track, caused by trapped dust particles or insufficient lubrication.
My suggestion:
- First, thoroughly clean the track with a soft brush or compressed air to remove dirt.
- Then, I recommend using a dry lubricant (such as PTFE) instead of oil, since oil attracts dust and dirt and quickly becomes sticky.
- In cases of severe wear on the sliders or tracks, replacement parts usually bring significant improvements.
One last tip: avoid aggressive cleaning agents that could damage plastic components.
These steps will make opening smoother and closing quieter and more effortless.
KAULIS
30 Jul 2024 11:28
Jensson schrieb:
If the track is damaged or shows significant signs of wear, it is worth replacing the rails
This is the key point. Many people ignore wear and try to fix it only with lubrication, which only provides a short-term solution.
For a long-term fix:
- Check the tracks for unevenness or deformation.
- Replacement parts for the BESTA system are compatible and easy to install.
- Also make sure the drawers are properly aligned, as misalignment causes extra resistance and noise.
This way, you achieve a sustainable improvement in usability and a quieter operation.
