ᐅ How can I make BILLY shelves easier to assemble?
Created on: 5 Mar 2023 08:37
Lispu4
Hello everyone, I recently bought several Billy bookcases and want to assemble them in the most installation-friendly way possible. The included instructions are clear, but I keep encountering small difficulties during assembly, especially when precisely aligning the shelves and fitting the back panel. My question is: How can I optimize the assembly of the BILLY bookcases to make the process faster, easier, and more stable? Are there any special tools, tricks, or perhaps modified methods you would recommend? I am particularly interested in tips for preparation or improvements to the assembly process.
tyson51
5 Mar 2023 12:45
I generally recommend attaching the back panel about halfway through the assembly. This means roughly fitting the side panels and shelves together first, then inserting the back panel for stabilization, and finally securing and adjusting everything. For tools, I suggest using a Phillips screwdriver bit with a torque clutch on a cordless drill to prevent over-tightening. Additionally, applying wood glue in the dowel holes helps increase stability, especially if the material will be standing for an extended period.
barEsperan
6 Mar 2023 07:28
One more tip: Use wood shims or small wooden wedges to fit the floors. This allows you to fine-tune the positioning and prevents the floors from slipping or getting stuck right from the start.
gekira
6 Mar 2023 08:31
Lispu4 schrieb:
Are there any specific practical experiences regarding the best time to install the back panel?
From a technical perspective, the back panel serves to reinforce the shelf unit. By gluing or screwing it in during assembly, a bending-torsion effect is created. This prevents warping. Therefore, it is advisable to attach the back panel only after the side panels and shelves are securely in place but still allow for fine adjustments. Typically, this is around 50-70% of the way through the assembly.
Repar
6 Mar 2023 10:18
I have had good experiences with initially screwing in the screws only loosely during assembly. This way, adjustments can still be made if necessary before everything is finally secured. After that, tighten the screws firmly.
boelnu
6 Mar 2023 11:42
Repar schrieb:
Initially, only screw in the screws lightly
Yes, that helped me as well; it reduces the pressure and helps avoid misaligned assemblies. Although Billy is not a premium product, with some patience the result can still be very satisfactory.
Lispu4
7 Mar 2023 09:07
Thank you all for your many helpful responses so far. In summary, the installation seems to work best when you first sort the individual components, prepare them by lightly pre-drilling or partially screwing, and then fit the back panel in the center to ensure stability while still allowing flexibility for fine adjustments. It’s good to know that careful use of wooden wedges and rubber mallets also helps with fitting. I will try it this way and report back 🙂
