ᐅ How can I make BILLY shelves child-safe and stable?
Created on: 26 Mar 2017 09:17
Lonku
Hello everyone, I have several Billy shelves from IKEA at home that I want to make child-safe and stable. My children are still small, and I’m concerned that the shelves could tip over or that they could be injured by falling books or objects. I am particularly interested in specific methods and materials for securing the shelves to the wall, as well as reinforcing them internally. Are there any special wall fasteners that work particularly well? What alternatives are there to traditional screw fixing? Also, are there proven tricks to make the shelves sturdy against tipping without having to completely rebuild them? I’m looking forward to your experiences and tips, including advice on proper installation and safety. Thanks in advance!
KAMERON
26 Mar 2017 12:23
For stabilizing Billy shelves, I recommend the following: 1. Use heavy-duty anchors for walls made of concrete or brick. 2. For drywall (plasterboard) walls, always use fischer DuoPower anchors. 3. Attach the supplied L-brackets at the top of the shelf with direct screws into the masonry. 4. Inside, you can reinforce the shelves by strengthening or doubling the back panel with a thin metal plate. 5. To further reduce the risk of tipping, wall connectors that link the shelves together are advisable. If the shelf will be used in a child-friendly environment, make sure to also use corner and edge protectors.
draleo
26 Mar 2017 12:50
ottilie schrieb:
If that thing tips over, the kids learn something
I consider this attitude dangerously underestimated. Child safety is based on prevention, not on trial and error.
Regarding stability: the arrangement of items significantly affects the risk of tipping. Heavy objects should be placed at the bottom, lighter ones on top. An additional cross brace behind the shelf greatly increases its rigidity. I also recommend using plastic corner brackets instead of plain metal ones, as they are more flexible and better absorb movement.
Lonku
26 Mar 2017 13:30
Thanks in advance for the responses, especially to Laurence and KAMERON for the detailed explanations! A quick follow-up question: The idea of reinforcing the back panel with metal sounds interesting. Does anyone know the proper way to do this? Would you simply screw an aluminum sheet onto the inside of the back panel, or is there a gentler method? Of course, I don’t want to damage anything or make the shelf unstable. Also, what about universal edge protectors – are they effective at reducing injury risks from the sharp edges of BILLY shelves?
Laurence
26 Mar 2017 14:05
Hello Lonku, you can reinforce the back panel by attaching a thin aluminum sheet or plywood with screws. Make sure the screws are not too long, as they might come through the front of the shelf panel. Alternatively, you can use an MDF board, which is usually easier to work with. It is important that the panel fits flush without any gaps to increase stability.
Edge protectors are definitely a good idea, especially if you have small children. There are soft foam or rubber protectors that are easy to install and can help prevent injuries.
anlu67
26 Mar 2017 14:38
I always use these self-adhesive rubber edge protectors. They provide good protection and keep the shelf stable. Don’t forget to screw it to the wall, otherwise it’s useless.
Tause
27 Mar 2017 09:12
Laurence schrieb:
Make sure the screws are not too long, otherwise they might protrude through the front of the shelf board.
This is an important point. The type of screw also matters: for thin back panels, smaller flat-head chipboard screws are better suited than standard wood screws. The flat heads distribute the force and prevent the material from breaking.
Additionally, consider where to fasten the panel—preferably in discreet locations, as you want to preserve the shelf’s appearance.
