ᐅ How can I protect IKEA Brimnes furniture from scratches?
Created on: 15 Jul 2022 09:03
Nimaplo
Hello everyone, I recently purchased several IKEA Brimnes furniture pieces, including cabinets and dressers with a white finish. I’m concerned about the durability of the surfaces, especially how to effectively prevent scratches. The plastic and foil coating seems quite delicate with everyday use, for example when placing or sliding objects on the furniture frequently. Does anyone know good strategies, materials, or maintenance methods to protect the Brimnes furniture from scratches over time without significantly affecting the appearance? I’m not looking for obvious covers that disrupt the design, but rather subtle and effective solutions. Thanks for any tips and experiences!
Davidleo
16 Jul 2022 08:32
Hey, I completely covered my Brimnes dresser with clear table protector PVC and I'm really happy with it! It provides perfect protection against scratches and is barely noticeable. This way, everything looks like new, even after 1 year. Definitely give it a try!
Lis53
16 Jul 2022 09:12
In addition to the tips already mentioned, I would like to point out that Brimnes furniture is not coated with scratch-resistant lacquer but has a foil covering, which is mechanically sensitive.
Regular cleaning with a microfiber cloth without aggressive cleaning agents also helps to keep the surface flawless for longer.
Important: Moisture should not be allowed to remain for extended periods, as the MDF can swell at the edges.
BARSAN
16 Jul 2022 10:59
Always use soft pads between the furniture surface and objects. I always use cork sheets to protect my Brimnes shelves; they also look nice and prevent scratches.
gadalu
17 Jul 2022 14:22
Nimaplo schrieb:
How easy is it to apply such films? Do you need any special tools, or can anyone do it themselves with some patience?
Applying a transparent protective film is quite manageable by yourself with some patience. It is important to have a dust-free and perfectly smooth surface, and to press the film on gradually to prevent air bubbles. A plastic squeegee or a small applicator tool can make the process easier, but it is not mandatory—a sturdy, smooth object (e.g., a credit card) also works well.
Recommendation: Practice on a small, inconspicuous area first. The films are flexible and can be readjusted if small bubbles appear after the first attempt.
