ᐅ How can I protect IKEA Brimnes furniture from scratches?
Created on: 15 Jul 2022 09:03
Nimaplo
Nimaplo
15 Jul 2022 09:03
Hello everyone, I recently purchased several IKEA Brimnes furniture pieces, including cabinets and dressers with a white finish. I’m concerned about the durability of the surfaces, especially how to effectively prevent scratches. The plastic and foil coating seems quite delicate with everyday use, for example when placing or sliding objects on the furniture frequently. Does anyone know good strategies, materials, or maintenance methods to protect the Brimnes furniture from scratches over time without significantly affecting the appearance? I’m not looking for obvious covers that disrupt the design, but rather subtle and effective solutions. Thanks for any tips and experiences!
EDWARD0
15 Jul 2022 09:17
I recommend using felt pads under heavy objects and avoiding placing sharp or hard items directly on the surface. Additionally, thin transparent protective films can help protect the surface.
gadalu
15 Jul 2022 09:46
The Brimnes furniture is made from melamine-coated particleboard, which is resistant to moisture and stains but does not completely prevent scratches from abrasion. To help protect it, I recommend:
- Felt or rubber pads under decorative items or electronic devices
- Soft placemats or protective mats for work surfaces
- Regular cleaning with mild, non-abrasive cleaners
A transparent self-adhesive film (e.g., polyurethane) can be applied directly to the surface, providing additional protection without affecting the appearance.
GIPAPO
15 Jul 2022 10:10
Use foil or protective film. Otherwise, always attach felt pads to furniture and decorations. Very effective and simple.
Nimaplo
15 Jul 2022 11:23
EDWARD0 schrieb:
I recommend using felt pads under heavy items and avoiding placing sharp or hard objects directly on the surface.
Thanks, that makes sense. Are there any specific felt pad brands or types you would especially recommend for IKEA furniture because they stick well and don’t slip?
gadalu schrieb:
A transparent self-adhesive film (e.g., polyurethane) can be applied directly to the surface and provides extra protection without affecting the appearance.
How easy is it to apply such films? Do you need special tools, or can anyone do it with some patience?
GALENKU
15 Jul 2022 11:50
For felt pads, I recommend the self-adhesive versions as they are easy to apply. When attaching the film, the surface should be clean and dry. A spatula or a clean card can help smooth it out to prevent air bubbles.
