ᐅ How do I install Ikea PLATSA furniture in sloped ceilings?
Created on: 24 Sep 2022 08:37
Dopar57
Dopar57
24 Sep 2022 08:37
I am planning to install several Ikea Platsa cabinet modules in a room with a sloped ceiling. The challenge is to customize and assemble the furniture so that it fits perfectly against the angled wall without losing too much space or compromising stability.
My question is: What strategies are there for properly and practically integrating PLATSA furniture in a room with a sloped ceiling? Specifically, I am interested in:
- How can I best cut or adjust the modules?
- What mounting options are recommended, especially for angled walls?
- Are there any special assembly tips to ensure everything is secure and stable?
- How does the appearance look when taking sloped ceilings into account?
I already have some basic knowledge of furniture assembly and DIY work, but I am looking for practical experience and as detailed advice as possible. Thanks in advance for your support!
Ryder35
24 Sep 2022 09:22
You should first precisely measure the angle of the roof slope. Afterwards, you can cut or simply bevel the sidewalls of the PLATSA modules to fit. For fastening, sturdy angle brackets that you attach to the wall are suitable. Make sure to secure them firmly in the wall, especially when dealing with a slight slope. Visually, it helps to adjust the fronts to the slope or to install a shelf board that accommodates the angle.
fikeo
24 Sep 2022 10:51
Hello Dopar57,
I think your question is very well formulated and important – adapting PLATSA to fit a sloped ceiling is definitely tricky but doable.
Basically, I recommend approaching the slope with patience:
- Measure the angle very precisely using a protractor or bevel gauge, as an accurate angle is key.
- The back panels are often easier to adjust than the side panels, so try shortening the back panels to fit the slope first.
- Stability can be achieved by adding extra wall brackets, which you fasten with anchors into sturdy beams behind the wall.
- Make sure to cut clean edges when sawing, and if needed, smooth them with sandpaper to allow for good gluing or fitting.
- Another option is to install intermediate boards or blocks to compensate for the angle.
I also suggest building a model from cardboard or plywood before the final assembly to test the fit.
If you like, I can also provide more tips on aesthetics to make the room look harmonious.
theo63
24 Sep 2022 12:46
fikeo schrieb:
The back panels can often be easier to adjust than the side panels, so try first trimming the back panels to fit the slope.
I fundamentally disagree. The back panels of the PLATSA are non-load-bearing and offer little stability. If you trim the back panel to fit the slope, you lose the ability to rigidly fix the module against the wall. It makes much more sense to adjust the side panels and keep the back panel original, so the structure remains stable.
Additionally, the following points should be considered:
- The attachment to the roof rafter structure should be checked in advance to avoid causing damage to the building fabric.
- Anyone cutting the furniture must consider whether the stability will still be sufficient in the long term; otherwise, it is pointless.
I recommend a structural assessment before cutting, especially with custom-built solutions in sloped roof areas.
tra_nina
25 Sep 2022 07:29
For additional information and precise planning:
- Measuring is essential; it is best to use digital angle finders for more accurate results.
- Ikea PLATSA furniture is modular and basically allows combining individual modules or customizing them.
- To adapt to a sloped ceiling, it is advisable to assemble the modules individually rather than putting them together first, so that side panels or top boards can be cut precisely if needed.
- When mounting on the wall, make sure to drill into load-bearing elements (roof rafters/joists) and distribute heavy loads across multiple points.
- To improve the appearance, triangular top boards can be added; these can be custom-made by carpenters or at hardware stores.
This approach ensures not only a clean look but also the necessary stability.
edisonbla
25 Sep 2022 14:13
theo63 schrieb:
The back panels of the PLATSA are not load-bearing and have little stability.
That’s true, but with some clever tricks, you can still position the furniture nicely on a slope. For example, I cut the modules slightly to fit around my roof window and reinforced them with small brackets and battens – it looked great and is rock solid!
- Tip: Place a piece of wood against the slope as a guide; this makes cutting easier.
- Tip 2: Paint or treat the cut edges to prevent swelling.
Sometimes it’s really a case of “learning by doing,” but with a bit of patience, it works out very well!
