ᐅ How do I install IKEA Metod wall cabinets on drywall?
Created on: 13 Sep 2022 14:27
V
VERENA
V
VERENA
13 Sep 2022 14:27
I am planning to install some IKEA Metod wall cabinets in my kitchen on a drywall (gypsum board) wall. Since drywall is known not to have the same load-bearing capacity as solid walls, I am concerned about how to securely and permanently fasten the cabinets. Are there special fastening methods or materials you would recommend? How should I proceed to ensure that the cabinets remain safely mounted even under heavy loads (e.g., from heavy dishes) and do not cause damage to the wall?
I am particularly interested in how to plan the installation – for example, whether I need to install additional support structures or if there are suitable anchors or hollow wall anchors for drywall. I would appreciate detailed instructions or tips on safe drilling, aligning, and mounting. It would also be helpful to know if there are relevant differences when hanging multiple cabinets side by side.
Thank you very much for your advice!
FeAndreas1
13 Sep 2022 16:04
Hello Verena,
First of all, great job approaching this topic in such a structured way – this is really essential when dealing with drywall (plasterboard) walls.
Basically, drywall panels alone cannot support heavy wall cabinets – it all depends on the underlying construction. If you want to mount the cabinets on a simple drywall without any supporting elements behind it (e.g., wood or metal studs), regular anchors won’t help.
I recommend the following steps:
- First, check whether there are stud profiles or wooden battens behind the drywall. You can locate these using a digital stud finder/scanner that can detect both wood and metal.
- Ideally, mount the wall cabinets directly on these studs, as this allows you to transfer the load straight to the framework.
- If there are no studs, you should definitely install an additional substructure. For example, a sturdy wooden frame fixed to the wall with special heavy-duty anchors. The cabinets are then attached to this frame.
- Regarding anchors: heavy-duty cavity anchors are an option if the panel thickness and cavity depth allow. These distribute the load within the cavity behind the drywall and are stronger than standard anchors.
- Drilling should always be done with a drill bit without steps to create a clean hole. Positioning is critical – use a spirit level to ensure the cabinets hang perfectly straight.
- For multiple cabinets side by side: continuous mounting is especially important. Ideally, mount the cabinets on a stable support rail and fix only this rail to the wall. This way, the load is distributed optimally.
My tip: Sometimes the visible effort with drywall is so high that additionally screwing in profiles or even partially removing the drywall for new fastening makes sense. Safety before aesthetic compromises.
If you have exact measurements, wall construction details, or cabinet weights, feel free to provide more information, so I can assist you more precisely.
toril
14 Sep 2022 09:18
FeAndreas1 schrieb:
If you want to attach cabinets to a simple drywall without any load-bearing elements behind it (e.g., wooden or metal studs), a regular wall plug won’t help you.
I agree with that. The main issue with drywall is that its load-bearing capacity is extremely limited when relying on the panels alone, especially for dynamic loads.
Some important points:
- Always use a support batten (at least 18 mm thick) ideally made of wood, secured to the masonry behind with heavy-duty anchors.
- The Metod wall cabinets are then mounted on the support batten using the original mounting rails.
- Installing multiple wall cabinets requires a precisely level substructure, otherwise the load will not be distributed properly.
- Special cavity anchors (e.g., metal expansion anchors or butterfly anchors) can be used in some cases but are generally suitable only for lightweight fixtures.
Additionally, you should be careful when drilling to avoid weakening the drywall panels. Repeated drilling or oversized holes for anchors can quickly reduce the load capacity.
Be cautious with the load in any case, and if in doubt, install a substructure, as drywall panels can easily crack or break out otherwise.
kemeo68
14 Sep 2022 21:37
- Always use a support batten (at least 18 mm (0.7 inches) thick), preferably made of wood, which is fixed to the masonry behind with heavy-duty anchors.
I agree with that – but I want to question the common opinion here: Does it always have to be so complicated with an additional support batten?
Sure, drywall alone carries little to no load, but often there are at least wooden studs or metal profiles behind it that you can use with cavity metal anchors.
Here’s the thing: For most installations, people prefer to use the wooden batten right away instead of dealing with the strength or load capacity of those practical cavity anchors. That is often exaggerated, at least if you’re not using the cabinets as gym equipment.
One could argue that the safest and most maintenance-friendly method is the wooden batten, but if space is tight or you want to avoid damaging the wall, good quality anchors can also help – especially if you don’t expect too much weight.
Of course, my advice only applies if you are familiar with the existing wall structure; otherwise, it can definitely become critical.
NoValentin
15 Sep 2022 08:46
For installing IKEA Metod wall cabinets on drywall:
- Locate studs (wood or metal)
- Use heavy-duty anchors in the studs
- If no studs are available, attach a wooden batten horizontally with heavy-duty anchors to the wall
- Mount the cabinets onto the batten
- Make clean drill holes and level the cabinets with a spirit level
This will help prevent the risk of breakouts.
