rosariojan2 Mar 2022 08:17Hello everyone, I recently purchased the IKEA Metod kitchen system and want to install the drawers with the soft-close feature. My question is quite specific: How exactly does the installation of the Metod drawers work, especially with the integrated soft-close mechanism? I have the standard Metod drawer sets and the soft-close runners, but I find the IKEA instructions a bit brief and want to make sure I don’t miss any important steps or make mistakes during the adjustment.
I’m also interested in any special tips for installation, such as how to properly hang and precisely align the drawer fronts so that the soft-close works correctly and quietly. Perhaps there are also tricks to optimize the drawer’s smooth movement or to avoid errors, for example with aligning the runners or with screwing.
Thank you very much for your help!
Hey, great question! 😄 The installation of Metod drawers with soft-close is really well designed if you follow the right steps. First, I always insert the slides into the cabinet and make sure they are perfectly straight – this is super important for the soft-close function! Then you place the drawer onto the slides and click it into place. 🔧 For adjusting the front, I use the small screws on the front attachment, so you can perfectly align the height and depth. A useful tip: make the adjustments only after the drawer is fully inserted, then it closes smoothly! And if the soft-close doesn’t work, just check again whether the slides are properly seated in the track or if something might be stuck. Don’t be afraid, sometimes it takes a bit of patience, but it’s definitely worth it! Good luck! 😊👍
For the precise installation of IKEA Metod drawers with soft-close, it is essential to follow these steps:
- First, install the soft-close rails completely and perfectly level on the cabinet side. Uneven installation will cause malfunctions in the soft-close mechanism.
- Then, insert the drawer centrally and straight into the rails until it clicks into place.
- Next, mount the front panel: using the three adjustment screws, you can precisely set the front height, lateral position, and tilt.
- Check the operation by opening and closing the drawer several times. The soft-close activates only with a slight pull.
- Make sure to clean the rails regularly; dust or debris can block the mechanism.
Following this procedure ensures quiet and durable operation, as specified by IKEA.
rosariojan2 Mar 2022 13:16GLALEO schrieb:
Go ahead and try, sometimes it just takes a bit of patience, but it’s definitely worth it! Good luck! 😊👍 Thank you very much, that already helps a lot, especially the reminder about patience, which I appreciate. Regarding the adjustment of the front panel: Can someone explain exactly which screws control which axis and how to best adjust the depth? I have the impression that my front panel is still slightly too far forward and doesn’t close properly or align cleanly. Is there a standard setting for this, or is it more about a feel for when it’s correct?
rosariojan schrieb:
Can someone clearly explain which screws correspond to which axis and how to best adjust the depth? Sure, I will describe the adjustment for the Metod system:
- The front screw on the front panel is used for the depth stop, so that the front either sits flush against the cabinet side or stands just slightly in front.
- The two rear screws control the height and lateral alignment.
For optimal soft-close function, the front should close flush with the cabinet or have a gap of about 1-2 mm (0.04-0.08 inches) without large air gaps, allowing the closing mechanism to engage properly.
You can try small adjustments to find the right setting. It is important that the drawer does not jam and that the soft-close still pulls smoothly when closing.
