ᐅ How do I install Ikea Metod cabinet doors without visible screws?
Created on: 9 Jun 2017 18:17
MikulaHello everyone, I am planning to install my new Ikea Metod kitchen cabinet doors in a way that no screws are visible from the outside. Specifically, I am interested in which methods or special accessories I can use to attach the doors invisibly, without having to cover them afterward with trims or panels. I already have experience assembling furniture and know the common hinges, but it is important to me that the appearance of the doors remains clean and uninterrupted. Are there, for example, invisible fastening systems, special clips, or alternative mounting frames, or would I even need to make modifications to the doors or cabinet boxes? I am looking for a solution that fits precisely, is stable, and durable. Any recommendations with tips on implementation are welcome, even if it involves modifying the doors or sourcing specific accessories. Thanks in advance!
Basically, Ikea Metod doors are normally attached using visible furniture hinges with screws, but if you want a fully concealed installation, I recommend a different approach: - Use concealed cup hinges with offset mounting, located on the inside at the back of the cabinet - Use special internal mounting plates or clips that can be attached to the door frames - Alternatively: clamp or magnetic fasteners to avoid screws It is important to prepare the doors in advance with specific drilling positions; otherwise, concealed systems will not fit properly. Many “invisible” fasteners require additional mounting holes and sometimes modifications to the door frame. I also recommend using high-quality hinges to ensure long-lasting durability. Simply avoiding screws without a stable support may look better but can cause functional problems in the long run.
meson schrieb:
Use concealed cup hinges and install them from the inside of the cabinet. The screws will then be hidden on the inside. That’s true, but it’s a bit too simplistic. Anyone aiming for a truly flawless finish without visible screws should move away from standard flat-pack components and consider custom solutions. Why limit yourself to standard hardware screws when entirely different joining methods are possible? For example, invisible wooden connectors, dovetail joints, or hidden tongue-and-groove systems.
If you rely on plastic hinge screws, you will always have barely hidden spots, even with cup hinges. So either rethink your approach or accept compromises.
Please note: The standard installation for Ikea Metod cabinets uses cup hinges with visible mounting screws on the frame that go through the door. For a completely concealed attachment, the following options are recommended: - Use concealed cup hinges with eccentric mounting, which hold the door securely from the inside using a tension screw and have only minimal visible screws on the cabinet carcass. - Alternatively, angle brackets with hidden screw channels on the cabinet can be used, although this makes installation somewhat more complex. - Magnetic fasteners are only suitable for lightweight doors and have lower load capacity. - For timber frame doors, concealed groove hinges or so-called "clip" systems can be used to avoid screw mounting in visible areas. For most users, the cup hinge option offers the best compromise between stability, ease of handling, and appearance.
