ᐅ How can I install IKEA Metod cabinet doors quietly and precisely?
Created on: 17 Jun 2022 09:37
peo42
peo42
17 Jun 2022 09:37
I am currently facing the challenge of installing the doors of the IKEA Metod system truly quietly and precisely. It’s not just about simple attachment for me, but especially about ensuring the doors are perfectly aligned, open and close without any squeaking, and don’t need readjustment over time.
What are your best tips for installing Metod doors? How do you handle fitting the hinges, which tools do you use, and how do you adjust the gap dimensions perfectly without the doors sticking or being too loose?
I am also focused on noise reduction, so are there any specific techniques or materials (e.g., lubricants or special seals) you would recommend?
I look forward to your practical experiences and maybe some advice that IKEA itself doesn’t mention. Thanks in advance!
WARREN
17 Jun 2022 10:12
If you want to mount IKEA Metod doors quietly, make sure to tighten all hinge screws firmly, but not too tightly. Use silicone spray on the hinge pins to reduce friction. For precise alignment, always fully utilize the adjustment options on the hinges, adjusting the height first, then the side.
Jensson
17 Jun 2022 14:05
Hello peo42,
I’ll give you a structured approach on how I install Metod doors to ensure they are both perfectly aligned and run quietly:
- Preparation: Check that all hinges and fasteners are undamaged and that the door surfaces are clean.
- Installing the hinges: Attach all hinges in their designated positions on the door. Screw them in finger-tight.
- Attaching to the cabinet: Hang the door loosely to check the initial rough fit.
- Fine adjustment: Use the three adjustment screws on the hinge for height, depth, and lateral offset. The order is important: first align vertically, then laterally, and finally adjust the depth.
- Noise prevention: If needed, apply a drop of silicone oil or a special noise-reducing lubricant like WD-40 Specialist Anti-Noise on the screws. Avoid any greasy or dirty substances, as these attract dust.
- Final check: Open and close the door several times to identify any sticking points or noise.
A common mistake is tightening the hinges too much before precise alignment, causing the door to sit incorrectly and squeak.
I hope this helps you!
PEDRO40
18 Jun 2022 08:21
Jensson schrieb:
- Final check: Open and close the door several times to identify any sticking points or running noises.
I can definitely confirm that. Especially with my last project involving Metod doors, I was initially quite frustrated because one door made noises that only appeared sporadically.
What helped me was patiently checking everything step by step and not tightening the screws completely right away.
From this, I learned that the right product is often underestimated. I would also recommend occasionally oiling or cleaning the individual components before installing them.
In conclusion: Take your time if the doors aren’t quiet right away – they aren’t broken, but often just need a small adjustment. Good luck to everyone!
