ᐅ How do I install Ikea Metod cabinet doors during renovation work?
Created on: 22 Jan 2024 08:17
Fugibau
Fugibau
22 Jan 2024 08:17
Hello everyone, I am currently planning a renovation of my kitchen and want to install Ikea Metod cabinet doors on the existing Metod base cabinets. I am unsure about the correct way to attach the doors to the cabinets, especially since they involve a combination with soft-close hinges. Could someone please explain in detail the steps I need to follow, from preparing the hinges to precisely adjusting them so that the doors fit properly, do not rub, and close smoothly? I have already assembled the cabinets, but I have no idea whether I can hang the doors directly on the hinges or if I need spacers or specific screws. I would really appreciate a detailed step-by-step guide, including tips for alignment and fine adjustment of the doors. Thanks in advance!
U
usJamie
22 Jan 2024 08:43
You should first fully install the hinges on the cabinet. Then hang the doors and use the screws for fine adjustment. Pay attention to the position of the drill holes on the door panel, as these are usually clearly specified by Ikea. For soft-close, simply click the dampers into the hinges; this is usually straightforward.
TEOZAR
22 Jan 2024 09:05
Hello Fugibau, to give you more detailed help: First, firmly attach the hinges to the cabinet carcass. The mounting plate, on which the hinge sits, is usually fixed with two screws – it’s important not to tighten these screws too much to allow for fine adjustments later. You can adjust the alignment using the three adjustment screws: one for depth, one for height, and one for the lateral distance to the cabinet front. When hanging the doors, it’s helpful to have two people to align the door precisely and to gradually adjust the hinge settings using a screwdriver. For the soft-close function, make sure the damper clicks in properly. This ensures smooth closing. If you bought new hinges: pay attention to whether you have clip-on hinges or pivot hinges, as the installation varies slightly.
Fugibau
22 Jan 2024 09:23
TEOZAR schrieb:
First, attach the hinges securely to the cabinet body. The mounting plate, on which the hinge is fixed, is usually attached with two screws – it is important not to tighten these screws too much to allow for fine adjustments later.
Thank you very much for the clear explanation! I would also like to know whether I can attach the hinges directly to the cabinet side panels or if it is better to use the pre-drilled holes (cam lock fittings) on the Metod cabinets? And how can I tell if the Metod cabinet sides are prepared for this?
Lucien
22 Jan 2024 09:47
Fugibau schrieb:
I’m curious whether I should attach the hinges directly to the cabinet side panels or if it’s better to mount them using the special drilled holes (cam screws) on the Metod boxes?
The Ikea Metod cabinets come standard with pre-drilled holes for the hinges. The hinges are not attached directly to the wooden cabinet side panels but are mounted on a mounting rail, which fits onto the designated holes along the cabinet carcass edge. This mounting rail is secured with cam screws to allow easy adjustment later. So, check the cabinet sides: you should find several recessed holes designed to hold the mounting rails. Screwing the hinges directly into the side panels may make later adjustments more difficult and reduce stability. As a precaution, you can purchase the Metod mounting rails separately from Ikea if they are not included.
Fugibau
23 Jan 2024 07:58
Thank you, that helps a lot! One more detailed question: Is there a specific sequence to follow when attaching the hinges to the mounting rails and hanging the doors that I should definitely keep in mind? I’m concerned that doing it in the wrong order might prevent me from aligning the door correctly or could damage the hinges.
