ᐅ How do I install Ikea Metod cabinets on floors with significant unevenness?
Created on: 17 Jan 2023 19:47
RENAFAR
RENAFAR
17 Jan 2023 19:47
Hello everyone, I am facing the challenge of installing Ikea Metod kitchen cabinets on a floor that has significant unevenness. The height variations are about 1.5 to 2 cm (0.6 to 0.8 inches), which makes leveling and positioning the cabinets difficult. The usual adjustable feet reach their limit here, as they do not offer enough adjustment range. My specific question: What proven methods, materials, or tools can I use to install the Ikea Metod base and wall cabinets securely and neatly on such uneven floors? I am especially interested in whether it is worth using special leveling plates or if there are installation tips that are particularly helpful for the Metod series. Thank you in advance for any well-informed advice!
Charles
17 Jan 2023 20:11
It is good that you clearly describe the issue with the unevenness, as this is often the critical point during installation. Ikea Metod cabinets do have height-adjustable feet that can compensate for 2 cm (1 inch), but for greater unevenness, additional work is necessary. I recommend the following approach: lay out strips or thin wooden boards on the floor before assembly to initially level the surface. Then, precisely level the Metod cabinets using the adjustable feet. For the base, I would suggest using moisture-resistant plywood panels, as these are stable and less prone to warping. Alternatively, if the floor is very uneven, you can build a kind of “plinth” or base frame that serves as a reference for all the cabinets. It is important that the leveling solution remains durable and stable to prevent any tilting. For wall cabinets, a stable and perfectly straight base and cross rail securely mounted to the wall is essential, as floor unevenness cannot be compensated here.
dijan
18 Jan 2023 07:42
Charles schrieb:
I recommend the following approach: Lay down either battens or thin wooden panels on the floor before assembly to even out the surface first.
Exactly! I once tried to straighten a very uneven floor for my cabinet installation, and my trick was actually to create a level surface using smooth OSB boards or simple chipboards. If you think of it as a small foundation that initially ‘absorbs’ all the unevenness, you’ll have much less hassle when adjusting later. Tip regarding weight: Don’t use the very thinnest boards, as they can become unstable and patchy.
Another tip from experience: If a spirit level doesn’t help much during setup, a laser level can be really useful. It quickly shows you exactly where the panel needs to be adjusted instead of wasting hours fiddling around. And a little humor never hurts, because this often turns into a test of patience!
roryvin
18 Jan 2023 12:35
dijan schrieb:
Another tip from experience: If you have trouble leveling with a spirit level during installation, a laser level can also be very helpful.
This is relevant. In addition: For Metod cabinet installation on uneven floors, I recommend not only leveling the floor but also checking the straightness of the walls. Irregularities in the wall can cause issues since the wall cabinets often need to hang on a straight mounted rail. Therefore, be sure to inspect the wall structure before installation and, if necessary, make adjustments.
Floor leveling measures include using various panels, as plywood or OSB boards are not only sturdy but also relatively thin, preventing the cabinets from being installed unnecessarily high. Pay attention to the quality of the cabinet legs: replacement legs with larger adjustment ranges are available at Ikea or third-party suppliers. It is important that all cabinets stand at the same even reference height to ensure clean joints and proper door function.
emmett
19 Jan 2023 09:04
Install feet with a larger adjustment range or add additional wedges underneath. For significant unevenness, small wooden shims can also be inserted into the foot. Important: Ensure all cabinets are leveled to the same height; otherwise, doors and drawers may stick.
