I’ve noticed that the drawers of my Malm dressers (IKEA) no longer open and close as smoothly as they did at first. Especially in the lower section, there is a slight catching resistance that makes opening and closing somewhat stiff. This issue occurs with all the drawers in the series, though to varying degrees. The rails are not loose, there are no visible deformations, and I suspect it’s more likely related to dirt, worn sliding surfaces, or possibly the assembly.
Therefore, I’m mainly interested in how to improve the operation of Malm drawers so they run noticeably easier and smoother again. Are there any recommended natural or technical cleaning and maintenance methods for the drawer slides? What approaches have proven effective to repair or at least improve wear on plastic components or metal guides? And is it worth replacing individual parts that might be available for purchase?
I look forward to well-founded tips and experiences, including suggestions on tools and materials that should definitely be used or better avoided.
Thank you in advance!
Hello benadi,
first of all, regarding your issue with the Malm drawers: this problem actually occurs quite frequently and can have various causes, which can be identified through a thorough inspection.
I would first recommend removing the drawers completely in order to examine the slides and guides more closely. Most often, it is dirty or worn plastic sliders or metal tracks that increase friction. Cleaning should always be done with a lint-free cloth—start dry to remove loose dust, then you can use a mild cleaning agent. Be careful with aggressive solvents, as they can damage plastic parts.
Regarding maintenance products: I definitely recommend silicone-based sprays. Special lubricants designed for plastic and metal tracks are also very well suited because they do not leave residues and are not dust-attracting. Oil or grease, on the other hand, can cause problems, especially if it gets dirty.
If the plastic sliders on the tracks are severely worn or damaged, it is often possible to order replacements from the manufacturer. With Malm, this is usually straightforward. Replacing these parts can make a significant difference if they no longer run evenly along the tracks.
One last point is the assembly: make sure all screws are still tightened firmly and that the tracks are perfectly aligned. Even slight warping or uneven gaps can affect the drawer’s movement.
If you like, I can also provide a step-by-step guide on how to fully dismantle, clean, lubricate, and reassemble the drawers.
I’m curious to hear how it goes!
benadi schrieb:
“I’m mainly interested in how to improve the movement of Malm drawers so they run much more smoothly and easily again.”
Hello benadi,
I would like to add to Domau0’s excellent post with a simple system that can help you solve the problem in a structured way:
1. Inspection & Visual Check
- Fully extend the drawer and carefully examine the runners and slides for any looseness or visible damage.
2. Cleaning
- Remove dust and dirt by tapping out debris and wiping down.
- Use a sprayable plastic cleaner to remove any sticky residue.
3. Lubrication
- Do NOT use oil or grease, as these attract dust and cause sticking.
- Instead, use a silicone-based lubricant spray, which provides a clean and long-lasting lubrication film.
4. Check Replacement Parts
- If the plastic sliders are heavily worn or the rails are bent, replacement is worthwhile.
- For Malm drawers, IKEA usually offers individual sliders for purchase.
5. Assembly Check
- Ensure the runners are mounted perfectly parallel.
- Do not overtighten screws; nothing should bind.
Tip: If you notice slight squeaking or creaking when opening or closing, this usually indicates missing or uneven lubrication. Using durable silicone-based products keeps things quiet for a long time.
Personally, I use products like "WD-40 Specialist Silicone Spray," which is suitable for many furniture runners and does not attract dirt.
If you have any questions about acquiring the right replacement parts, I can gladly provide a source.
2. Cleaning
3. Lubrication
5. Assembly Check
Domau0 schrieb:
“If the plastic sliders on the runners are heavily worn or damaged, replacement parts can often be ordered from the manufacturer.”
