ᐅ How can I improve the load-bearing capacity of Ikea BESTA furniture?
Created on: 25 Jul 2020 10:03
turan53
I am specifically looking for ways to improve the load-bearing capacity of Ikea Besta furniture. In particular, I want to reinforce the TV unit and some individual cabinet elements to ensure they can easily handle higher weight loads.
I already have a few ideas in mind, such as adding extra braces or using stronger fasteners, but I would like to hear from others about which measures are truly effective without significantly affecting the appearance or functionality.
Does anyone have practical tips on materials or techniques that have proven useful? For example, how about reinforcing the back panels or the feet?
I look forward to well-informed suggestions, including any advice on potential weak points in the BESTA construction that can be addressed specifically.
hauklo
27 Jul 2020 14:05
PRABAU schrieb:
The best reinforcement is always to install additional brackets inside and, as mentioned, to replace the back panel with a thicker wooden panel.
This also matches my understanding. It is important to position the brackets correctly, especially at the corners and in areas with high load transfer.
Additionally, I recommend:
- Use screws of sufficient length that penetrate deeply into the material without causing splitting.
- When attaching to drywall (plasterboard), there should be at least one cross brace (e.g., a wooden batten behind the drywall); without this, there is a risk of pull-out damage.
- Regularly check the fasteners, as they can loosen under repeated loading.
LOC panels (laminated OSB) can be a good alternative to traditional back panels, as they provide firm support and are easy to work with.
Garry
28 Jul 2020 09:37
turan53 schrieb:
The furniture will be mounted on the wall, but not on a load-bearing solid wall—instead, it will be attached to a drywall with anchors.
In this context, you should design the furniture construction to be as self-supporting as possible, since drywall can only sustain low loads over time.
My advice:
- Reinforce the back panel as recommended with 8 mm MDF or OSB.
- Add additional bracing made of wood or metal on the side panels.
- Avoid placing heavy appliances on small contact points. Use a continuous reinforced shelf instead.
One often overlooked measure: check the floor’s levelness and use adjustable furniture glides to minimize deformation during assembly.
