ᐅ How can I improve the load-bearing capacity of Ikea BESTA furniture?
Created on: 25 Jul 2020 10:03
turan53Hello everyone,
I am specifically looking for ways to improve the load-bearing capacity of Ikea Besta furniture. In particular, I want to reinforce the TV unit and some individual cabinet elements to ensure they can easily handle higher weight loads.
I already have a few ideas in mind, such as adding extra braces or using stronger fasteners, but I would like to hear from others about which measures are truly effective without significantly affecting the appearance or functionality.
Does anyone have practical tips on materials or techniques that have proven useful? For example, how about reinforcing the back panels or the feet?
I look forward to well-informed suggestions, including any advice on potential weak points in the BESTA construction that can be addressed specifically.
GUSTAVO5626 Jul 2020 08:12Hello turan53,
to make the BESTA furniture more durable, it is advisable to reinforce the structure at critical points. Here is a detailed approach:
- Back panel: The original thin back panels are a weak point. I recommend replacing them with or adding an OSB or MDF board at least 6 mm (1/4 inch) thick. This significantly increases stability against lateral and rear forces.
- Fasteners: The supplied dowels and Minifix cam lock bolts are suitable for standard loads, but for higher loads, they should be supplemented with longer screws into metal strips or brackets. Use universal steel furniture brackets that fit precisely in depth.
- Bottom supports and feet: Additional reinforcement with beams made of squared timber or steel profiles can prevent the furniture parts from bending. Make sure the load is distributed evenly.
- Interior fittings: If you store heavy items, support the shelves with reinforcements, such as aluminum profiles or wooden wedges under the shelves.
I am interested to know what the load in your case is and whether the furniture stands freely or is secured to the wall. Wall mounting is highly recommended with the BESTA series anyway.
GUSTAVO56 schrieb:
I am interested in how much load there is in your case, and whether the furniture is free-standing or attached to the wall.Thank you very much for the detailed feedback!
To clarify: The load involves several heavy devices – for example, a large OLED TV, an amplifier system, and various media shelves, resulting in a total weight of about 35-40 kg (77-88 lbs) on the base cabinet. Additional loads on the shelves are rather moderate, but I want to be sure that even somewhat abrupt placing or moving of the devices doesn’t cause any issues.
The furniture is attached to the wall, but not to a load-bearing solid wall; rather, it is fixed to a drywall (plasterboard) wall using anchors. Therefore, I want to make the furniture itself stable enough in case the wall attachment does not hold the full load.
Preventing sagging and lateral deformation is my top priority.
Hello turan53,
It’s great that you are already thinking through these details carefully! For a load of 35-40 kg (77-88 lbs) in the TV furniture area, reinforcing the structure is a good idea, especially if the wall mounting is based on drywall.
In addition to the reinforcements you mentioned, I recommend paying attention to the following points:
- Wall mounting: Use heavy-duty anchors designed for drywall whenever possible, and distribute the fixings over a wide area to spread the load.
- TV furniture panels: Strengthen especially the lower shelves by adding cross braces or hardwood battens. These can be glued or screwed in from underneath.
- Joint edges: Make sure that the joints between panels are properly glued and screwed. Sometimes Ikea furniture has minimal reinforcement here since it is designed for light use.
- Feet: A solid base for the feet prevents sinking, which can cause concentrated load points.
- Alternative: There are useful retrofit options like steel frames or additional drawer slides with metal brackets that help distribute the load better.
If you like, I can also compile a list of suitable reinforcement profiles and helpful accessories for you.
