I have an issue with the drawer slides on my Malm dressers: when pulling the drawers out, they often feel a bit wobbly and don’t provide the level of stability I would expect. Especially when the drawer is loaded a bit heavier, it seems like the slides give slightly or don’t run completely smoothly.
I’m particularly interested in how to improve the stability of the Malm drawer slides without having to do major modifications or replace the entire hardware. What tricks, installation adjustments, or additional measures would you recommend to optimize the stability and smoothness of the slides?
I’m looking for a practical solution that makes the original system a bit more robust. I would appreciate it if you could share your experiences, tips, or possible pitfalls to watch out for when improving these drawer slides. Thanks in advance!
jonfu schrieb:
I’m especially interested in how to improve the stability of the MALM drawer runners without having to do major modifications or replace the entire parts.Hey, you’ve come to the right place! 🙂
A common issue with MALM drawers is that the small plastic clips holding the drawer in the runner tend to stretch out or break over time. This makes the runner feel quite loose. A great tip is to either replace these plastic holders or apply a small strip of double-sided tape to the rails to add a bit more tension.
Also, sometimes simply tightening the screws on the runner helps – it’s easy to overlook how loose those connections can get.
Finally, for a really reliable fix, you can add thin felt or rubber strips at the contact points. These create minimal resistance while also reducing rattling. This not only improves stability but also gives a smoother feel when pulling the drawers.
Good luck! 🙂
Wesley schrieb:
A common issue with Malm drawers is that the small plastic clips holding the drawer in the track tend to loosen or break over time.It’s hard to describe the problem more precisely.
To add some details: The Malm drawer slides operate on ball bearings that allow for smooth extension. Over time, wear or contamination such as dust and grease can reduce the system’s precision.
A practical approach to improve the drawer’s stability is:
1. Clean all rails and ball bearings with an appropriate cleaner to remove dust and dirt.
2. If necessary, lubricate with a very thin grease that is neither sticky nor too thick.
3. Replace the plastic parts if they are damaged.
4. If there is excessive play, adjusting the screws on the furniture and drawer can help improve the fit.
5. For increased stability, small metal strips can be added as reinforcement, but only if you have solid DIY skills.
These steps are mostly reversible and do not significantly alter the furniture.
jonfu schrieb:
What tips, installation adjustments, or additional measures do you recommend to improve stability and guiding performance?From my experience, the most important step is first to identify the cause of the guide giving way.
The most common cause is incorrect installation, especially when the guide rails on the dresser or drawer are not mounted exactly parallel. This leads to tension and increased play.
Therefore, I strongly recommend the following procedure:
- Remove the drawer and guides
- Check the mounting angles, if necessary with a protractor
- Adjust or realign the guides
- Use small washers between the screw heads and the guide rails to gently press the guide without tape or similar
- Check whether the wood at the fixing points has become worn out. If so, larger screws or wood filler can help.
Only if mechanical adjustments remain unsuccessful would I consider further measures.
Keatondra20 Sep 2020 07:54Jonfu schrieb:
So it’s about a pragmatic solution that makes the proven original system a bit more robust.I would like to add that Malm dressers are generally not designed for very heavy loads. Even the best reinforcements have their limits when the drawers are heavily loaded.
To improve the stability of the drawer slides, I also recommend:
- Checking whether the slides are properly engaged (often, the drawer is not fully snapped in)
- Replacing the original screws with ones of a larger diameter (handle wood carefully)
- If needed, reinforcing the mounting points with wooden strips or small wooden plates as backing
If there are any wood chips or damage, repair immediately, as this causes uncontrolled movement.
A little care during assembly usually has the greatest effect. Additionally, I would advise limiting the drawer load to the recommended maximum weight.
