Hello everyone, I recently bought a Billy cabinet and am a bit dissatisfied with the doors. They especially creak and stick when opening and closing, which can be quite annoying over time. Additionally, the doors don’t seem to fit perfectly flush – there are slight gaps that are clearly visible. My question is: How can I technically and practically improve the doors of my Billy cabinet so that they run smoothly again, make no noise, and close properly? Are there any special adjustment tips or better hinges that I could use? I would really appreciate practical advice and explanations, especially if you have had similar experiences yourself.
Mar46 schrieb:
Do you apply it directly on the hinges? Could this cause long-term damage to the metal or the surface?I have always sprayed the lubricant directly on the hinge pin, where metal moves against metal. I have been sparing when applying it to the door frames themselves. So far, no damage has occurred. However, you should be more cautious with wooden surfaces. It might be a good idea to test it somewhere first.
Mar46 schrieb:
Are there any specific models you would recommend?I bought these Blum soft-close hinges, which are very easy to install and highly reliable. The installation manual is included, and there are plenty of helpful YouTube videos as well. I encourage you to give it a try! The result is really excellent 🙂
A quick update from my side: I loosened the hinges and realigned the doors. During this, I noticed that one screw in a hinge was almost completely unscrewed, which was likely the main cause. Afterwards, I tested silicone spray – the operation is now super quiet and smooth! However, I still have slight gaps, especially at the upper corner. Should I focus on adjusting the hinges or the door itself here?
