ᐅ How can I neatly and safely conceal cables inside IKEA BESTA units?
Created on: 24 Feb 2020 18:37
Ploti57I am planning to use my IKEA Besta furniture as media and storage units in the living room. My question is how to hide the many cables from the TV, game console, soundbar, and other devices as neatly and safely as possible, without hindering airflow or making maintenance difficult. Does anyone have experience with routing or concealing cables effectively and cleanly through the cabinet bodies? I am particularly interested in tips for cable grommets, possible modifications to the furniture itself, avoiding cable clutter, and safety considerations when running electrical cables inside furniture. What solutions have worked well for you, especially with the sturdy but simply designed BESTA cabinets?
For elegant and safe cable management in IKEA BESTA furniture, planning the cable routing is essential. It is recommended to use wired cable grommets installed in the back panels or rear walls. A minimum distance from electronic devices should be maintained to prevent heat buildup. The easiest approach is to drill holes at specific points during furniture assembly or use existing cable openings to bundle and route cables neatly to the back. Additionally, cable ducts or flexible spiral sleeves can be used to keep things organized and to protect the wires from mechanical strain. It is also important to place power strips in protected locations to facilitate operation and to prevent short circuits caused by cables being pinched inside the furniture.
Here is a brief guide for cable-friendly organization of your BESTA furniture:
- Step 1: Identify all devices and their cable lengths to plan the cable routes effectively.
- Step 2: Use existing holes in the back panel or carefully drill cable openings with a fine drill bit, for example directly behind the devices.
- Step 3: Route the cables using flexible cable ducts or spiral wraps to protect them from damage and maintain a clean appearance.
- Step 4: Use cable ties to bundle loose cables, ensuring enough slack to prevent cables from bending or kinking.
Common mistakes:
- Placing cables directly on the bottom surface of the furniture, where dust and heat tend to accumulate.
- Bundling cables too tightly, which can put pressure on the wires.
In my experience, self-adhesive cable clips attached to the inside of the BESTA cabinets work well — they keep cables in place without affecting the look.
Common mistakes:
KarTristan26 Feb 2020 11:15KUDAISY schrieb:
Common mistakes:
- Laying cables directly on the bottom of the furniture, as dust and heat often accumulate there.
- Tying cables too tightly, which puts pressure on the wires.That sums it up well. Additionally, I recommend paying close attention to the heat generated by connected devices. BESTA furniture is not very breathable, so the space behind the devices should be adequately ventilated. Small spacers can also be installed on the back panel to prevent cables from being fully compressed and to allow better air circulation.
Furthermore, I find it useful to route the main cable bundles upwards or to the side of the cabinet to avoid tripping hazards when handling and unplugging. When in doubt, careful planning before installation helps – for example, creating a detailed sketch of the cable routing in advance.
