Hello everyone, I recently received a new kitchen with IKEA Metod matte finish fronts and am currently unsure about the best way to clean them gently and effectively.
I am particularly interested in which cleaning products I can use without damaging the matte surface or making it shiny. Are there specific techniques to keep the fronts looking matte and fresh for a longer time?
Additionally, I would like to know how to deal with stubborn stains without harming the surface.
I appreciate any detailed answers, as I am not yet familiar with the material and want to treat the surface with care.
Regarding tomato sauce and greasy stains: If the usual dishwashing detergent method is not enough, you should use at most a specialized plastic cleaner suitable for matte films and melamine.
Be careful not to rub too hard and avoid abrasive sponges. The surface is often up to 1 mm (0.04 inches) thick and consists of a UV-cured protective layer – it is sturdy but can scratch easily if handled improperly.
If you want, you could try a cleaning spray designed for matte surfaces, but always test first in a corner area and never on wood or other sensitive spots.
I find the discussion here very helpful because I had the same concerns about the matte finish. Often you wonder if you’re being too cautious and whether the surface might warp or change over time.
In my experience, regularly wiping with a microfiber cloth and a mild dish soap solution is enough – then you simply let the fronts air dry. You’ll notice that the matte surface stabilizes after a few weeks and doesn’t develop shiny spots.
The advice to gently wipe and avoid alcohol-based cleaners is, in my opinion, really key.
Great thread! Thanks for all the helpful tips. I was unsure at first and actually used a cleaner that wasn’t suitable by mistake – now the surface has a slight shine in some areas.
It’s important to treat that right away and then gently wipe again with a mild cleaner to at least minimize the effect. But the best approach is to be careful from the start, which I also learned!
Hartwigpo7 Mar 2023 14:17retau schrieb:
At first, I was also unsure and actually used a cleaner that was not suitable – now the surface has a slight shine in some areas.Thank you for sharing your experience. From your perspective, are there any ways to dull or correct the unwanted shiny spots? Or is replacing the panels the only solution?
Hartwigpo schrieb:
Are there any ways, in your opinion, to dull or correct unwanted shiny spots?Unfortunately, this is challenging. The matte surface is not a film that can simply be replaced, but rather a top protective and design layer. Shiny spots usually result from UV damage or chemical exposure.
Sometimes, very fine sanding with ultra-fine sandpaper can help, but this requires experience and carries risks. Alternatively, trying a matte furniture polish might offer slight smoothing effects, but it rarely enhances the matte finish on shiny areas.
Replacing individual panels is usually the most reliable solution, although it can be costly.
