ᐅ How can I gently clean Ikea Hemnes furniture?
Created on: 12 May 2023 08:37
Mauro1
Mauro1
12 May 2023 08:37
Hello everyone, I have a question about the gentle cleaning of Ikea Hemnes furniture. The Hemnes series is known for being made of solid pine wood and often has a painted or oiled surface. I want to avoid damaging the finish with the wrong cleaning products or methods, such as dulling the paint or allowing moisture to penetrate the wood. Are there any recommended procedures or special cleaning products that work particularly well for this furniture series? Ideally, instructions that also cover common types of dirt, like dust, fingerprints, or everyday stains, would be helpful. I would appreciate any tips on how to care for my furniture without stressing the material.
Tevin
12 May 2023 09:51
Hello Mauro1, your concern is completely understandable, as Hemnes furniture requires careful handling due to the types of wood and finishes used. In general, the following applies to such furniture: - Use a soft, lint-free cloth, preferably microfiber. - Damp wiping is possible, but the cloth should only be slightly damp to avoid overloading the painted or oiled surface with moisture. - Avoid aggressive cleaning agents that contain solvents or strong alkalis, as they can damage the finish. - For light dirt such as dust, dry wiping is often sufficient. For more stubborn stains, you can dissolve a mild dish detergent in water and use the slightly damp cloth. - After cleaning, wipe the surface again with a dry cloth to ensure no moisture remains on the wood. Avoid abrasive sponges or harsh brushes. Special wood care products that are wax-based or neutral can be used occasionally to protect the surface, but please not too often to prevent residue buildup on the finish.
meGreg
12 May 2023 10:23
Hey Mauro1, I have Hemnes furniture at home myself and maintain it with a simple trick: I mix a small amount of mild dish soap with lukewarm water, take a soft cloth, and wring it out really well. 🙂 Then I wipe down the furniture and dry it immediately. This works great for removing dust and fingerprints. The important thing is not to use too much water, as the wood can swell, which nobody wants. Oh, and avoid harsh chemicals, or the nice finish will fade faster than expected. If the furniture is particularly dirty, just dip the cloth briefly in the mixture again without soaking the furniture. This way, the Hemnes pieces stay beautiful and clean—almost too nice to sit on! 😉
Domau0
13 May 2023 07:42
Mauro1, your question actually requires a detailed answer because the Hemnes models can have different finishes (painted, oiled). First, let me explain the difference: Painted surfaces have a protective layer, while oiled surfaces are more porous and require different care.
For painted Hemnes furniture:
- Use only mild, pH-neutral cleaning agents.
- A soft, damp cloth is sufficient; wipe dirt away rather than rubbing it in.
- Always dry afterwards to prevent water marks or swelling.
For oiled surfaces, caution is needed:
- Avoid using large amounts of water.
- Use special wood oils or care products that protect and nourish the wood.
- Wipe off stains as soon as possible.
A small note: If you’re not sure whether your furniture is painted or oiled, checking the product description or the back of the item can help – Ikea often provides care instructions there.
Regarding stains:
- Dust can usually be removed with a dry cloth.
- For fingerprints, use a slightly damp cloth.
- Dried-in stains can be treated carefully with a very mild cleaner, but never scrub too hard.
If you often have trouble with stubborn stains, feel free to describe the types of stains in more detail, and I can provide further tips.
Mauro1
13 May 2023 09:05
Thank you for the initial helpful information! Regarding the surface: According to the purchase documents, my Hemnes dressers are lacquered. The surface feels smooth and glossy, so it is not oiled. Unfortunately, I still occasionally have the problem that small matte spots appear, especially with slightly greasy fingerprints and water marks. So far, I have mostly cleaned them with a sponge and some dish soap, which, according to your suggestions, might sometimes have been too "wet."
I would be interested to know if you can recommend a way to effectively but gently remove these fingerprints and water marks without damaging the lacquer? Are there any special cleaning cloths or home remedies that are suitable for such cases?
LOGEMIN
13 May 2023 12:17
Hello Mauro1, based on your information, I can provide you with clearer instructions.
1. Preparation:
- Always remove dust first with a dry microfiber cloth.
2. Fine cleaning for fingerprints and water spots:
- Lightly dampen a cloth with warm water.
- Add a drop of mild dish soap and wring the cloth out thoroughly.
- Gently wipe the affected areas, do not rub.
- Immediately wipe again with a dry, soft cloth after cleaning.
3. Special care cloths:
- Microfiber cloths without aggressive chemicals are recommended.
- Caution: avoid scouring pads or paper towels, as they can cause micro-scratches.
4. Alternative home remedy:
- A mixture of equal parts water and distilled white vinegar can help remove water spots. Use sparingly, as acetic acid can damage wood surfaces.
5. Long term:
- Once or twice a year, a polish for lacquered furniture can be used to refresh the protective coating. Please choose a product specifically designed for lacquered wood surfaces.
A common source of problems is too much moisture on the wood, which you should avoid. In your case, wiping multiple times to dry is definitely advisable.
