Hello everyone, I have a small problem with my IKEA Platsa shelves that I assembled some time ago. Although they are fairly functional, I notice that they are quite wobbly in some areas, even when I screw them to the wall. I’m interested in how to best stabilize these wobbly shelves without having to buy expensive additional fittings. Are there proven methods to improve the stability of the individual shelf units, for example through reinforcements or other techniques? Which tools and materials should ideally be used, and what should be especially considered during assembly to ensure the shelves remain secure even after extended use? Has anyone had similar experiences and can offer advice? Thanks in advance for your help!
FABIAN_DEO4 Apr 2015 09:12Hello lentan,
First of all, it is important to understand that the stability of the PLATSA shelves depends heavily on correct assembly and wall mounting. I will go through some key points step by step that you should check:
- Screws & connection points: Often, the fasteners are not tightened enough or some screws were skipped. It helps to retighten all screws (especially the connecting brackets and cam screws).
- Wall mounting: For PLATSA, wall fixings are essential. Make sure to use anchors that match the wall type (e.g., cavity wall anchors for drywall). Check the screws in the wall studs or profiles; they should not be loose.
- The shelf itself: If individual modules wobble, you can retrofit small angle brackets at the joints—ideally from the inside so they remain hidden.
- Material fatigue: Sometimes slightly cracked or bent parts can cause problems. I recommend checking the parts individually and replacing or reinforcing them if necessary.
Regarding tools:
- A cordless drill with torque control is ideal.
- A spirit level to ensure the shelf is perfectly straight.
- Wood/metal brackets for reinforcement.
One more question: Have you already fully secured the shelves to the wall, or are they still free standing? That information would help me assist you more precisely.
Regarding tools:
FABIAN_DEO schrieb:
One more question off the side: Have you already fully fixed the shelves to the wall, or are they just standing loose?Thanks for the detailed response! The shelves are actually fully attached to the wall, but without special wall anchors since the wall is quite solid. All the screws are in place, but I haven’t tightened them again yet—I’ll do that today. So far, I haven’t installed any corner braces, but that sounds promising. I’ll try to discreetly attach some at the connection points. Is there anything you would recommend avoiding, for example regarding the position of the braces or the type of screws? Do you have any tips for choosing the right braces? Are there perhaps more affordable alternatives to the original IKEA fittings that still provide adequate support?
Hello lentan,
here are some practical tips regarding angle brackets for PLATSA shelves:
- Make sure the brackets are made of steel and have no rust spots.
- Use screws that are long enough to securely penetrate the wood, but not so long that they come out the other side.
- Position the brackets at the corners where two panels meet, preferably on the inside corners. This way, they are barely visible from the outside.
- Alternatively, you can use so-called "flat brackets," which are less noticeable.
- Pre-drill screw holes to avoid splitting the wood.
Avoid mounting the brackets directly on the front side of the shelf parts, as this can look unattractive and damage the surface.
An affordable alternative to the original IKEA fittings are standard furniture brackets from hardware stores, which often provide even better stability because they are thicker and stronger.
Good luck stabilizing!
mifusau schrieb:
Pre-drill the screw holes to prevent the wood from splitting.That’s a very good tip! In addition, I would like to mention that when assembling PLATSA shelves, you should also make sure to position the connector plates (the metal brackets provided by IKEA) correctly. These are designed to join and stabilize the panels.
If your system is modular, you might also consider connecting multiple modules together before attaching them to the wall.
Here is my recommendation in brief:
- Attach and check the connector elements properly
- Tighten the connector screws
- Level the shelves (use a spirit level)
- Install corner braces on inner corners
- Use screws and wall plugs with the right dimensions
And don’t forget: distribute loads evenly and avoid overloading—especially with these plug-in systems, uneven loading can cause wobbling.
Try out these suggested steps and feel free to share how it goes.
Hello lentan and everyone interested,
I would like to share my experience with stabilizing PLATSA shelving units, as this topic concerned me some time ago.
First: The PLATSA design is based on a slot and screw system that is sufficient for lighter loads when assembled normally, but can start to wobble under heavier weight if no additional reinforcement is added.
My recommendations for long-term stability:
- Always use proper wall fixing with appropriate anchors, no matter how solid the wall seems. The shelves need to be securely anchored.
- If you have multiple modules, connect them firmly using the Ikea connector plates, but I have often added small metal brackets from the inside as well, which greatly improves load transfer.
- Tighten the screws at the connection points again after about a week. The wood and fasteners often settle.
- Additionally, you can install wooden battens inside the hollow sections of the shelves for reinforcement. This adds a significant amount of stiffness.
- Use screws tightened to a clearly defined torque to achieve the proper clamping force—neither too tight nor too loose.
- Finally, check the shelf depth—some shelf segments are narrower and thus less stable. A newer Ikea PLATSA layout or so-called back panels (sliding covers) can help prevent instability.
These tips have helped me maintain a stable and wobble-free storage solution through several moves.
Best regards!
Best regards!
