ᐅ How can I fix the issue with loose IKEA Metod screws?
Created on: 31 Oct 2020 09:23
Mugikeo
Mugikeo
31 Oct 2020 09:23
Hello everyone, I recently assembled some Ikea Metod kitchen cabinets and encountered a recurring issue: some of the screws, especially those securing the cabinet sides, become quite loose after a few days. This obviously affects the stability and overall functionality of the furniture. I have tried tightening the screws again, but that only helps temporarily. My guess is that the material around the threaded area has worn out or that the screws are not able to apply enough clamping force to the wood. Does anyone have practical tips or proven methods for reliably fixing these loose screws? I would prefer more creative solutions than just using larger screws or expensive specialty products. Thanks in advance for your experiences and advice!
kaju67
31 Oct 2020 10:11
Hey Mugikeo, that sounds really annoying—I've experienced similar issues with my IKEA projects 😉. For loose screws in Metod cabinets, I often use some simple DIY tricks:
- Fill the hole with wood shavings or small wooden chips before inserting the screw. This provides better grip.
- Alternatively, mixing some wood glue with sawdust can help fill the threading slightly.
- If it’s very loose, you can use a slightly thicker dowel that fits into the hole to stabilize the screw threads.
I find this offers a good balance between effort and result without having to take the entire unit apart right away. Sometimes, just tightening the screw snugly by hand without overtightening can prevent the hole from wearing out.
Ramon4
31 Oct 2020 11:07
Hello Mugikeo,
I understand your situation well; this issue is quite common with particleboard furniture.
A few suggestions I would recommend:
- If the screws are slipping in the material, it is often because the threads are stripped or heavily damaged.
- Insert a small piece of wood into the old hole, let the glue dry, and then carefully drill a new, slightly smaller hole for the screw.
- Alternatively, you can use special wood-thread inserts for Metod screws. Although this is a small investment, it provides lasting stability.
- If you still plan to assemble the cabinet, be careful not to overtighten the screws, as this can make the material even more vulnerable.
If you like, I can also provide a step-by-step guide.
Dopoki
1 Nov 2020 08:44
Ramon4 schrieb:
A few points I would recommend:
The recommendations are solid. Additionally, I would like to point out the following:
- Metod screws are usually used in particleboard with a melamine coating, meaning the material is not as strong as solid wood.
- To prevent loosening, it is best to remove dust and loose particles from the screw holes before repairing them.
- Commercially available thread-locking adhesives (medium-strength, removable types) can be applied to the threads to stabilize the connection.
- If the material is too soft, inserting a small wooden or plastic dowel can help create a better thread.
I recommend a three-step approach:
1. Remove screws and clean the holes.
2. Fill the holes with wood glue and sawdust or insert dowels.
3. After drying, carefully reinstall the screws and use thread-locking adhesive if needed.
This way, you will achieve a long-lasting, secure mounting.
moses
2 Nov 2020 14:02
I really appreciate that you approached this topic in such detail, Mugikeo. It’s easy to get stuck in frustration when furniture doesn’t work as expected.
Mugikeo schrieb:
I tried tightening the screws again, but that only helps temporarily.
I know that feeling all too well, and sometimes it seems like you’re left alone with a small but annoying problem.
What I’ve learned is that patience and a bit of experimentation can help. For example, the last time I dealt with a stripped screw hole, I filled it with double-sided tape and some wood filler – not the most elegant fix, but it held up better than I expected.
Maybe you could also consider contacting the Ikea support. Sometimes they have replacement parts or advice that aren’t available in-store.
In any case, I’m keeping my fingers crossed that you can fix this quickly and don’t end up throwing the brackets out the window in frustration!
