ᐅ How can I fix squeaking hinges on Ikea Pax wardrobes?
Created on: 28 Dec 2021 20:37
Feneje
Feneje
28 Dec 2021 20:37
I’ve noticed that the hinges on my Ikea Pax wardrobe keep squeaking when I open or close the doors. It’s not only annoying but also gives a somewhat low-quality impression, even though the wardrobe itself feels quite sturdy.
I’ve done a bit of research and understand that hinges can vary from metal hinges to those with plastic bearings. The Ikea Pax hinges, as far as I can tell, are standard concealed hinges with soft-close functionality.
My main question is: What is the best way to repair or maintain these squeaky hinges to stop the noise? Are there recommended lubricants, special techniques, or do the hinges need to be removed and cleaned?
If it’s relevant: the squeaking tends to happen more in cold weather and after the wardrobe hasn’t been used for a while. The doors still move smoothly, with no sticking or jamming.
I would really appreciate any helpful tips, including links to suitable products or practical experiences!
rekijan
28 Dec 2021 21:04
Feneje schrieb:
As far as I can tell, these Ikea Pax hinges are standard soft-close folding hinges.
Hey, you’ve already identified it pretty well! The hinges on Pax wardrobes are usually soft-close folding hinges that sometimes like to put on a little squeaking concert.
Personally, I swear by a simple household remedy: WD-40 or another light penetrating oil. But be careful—not too much, or it will run off and leave grease stains on the cabinet that you definitely don’t want. Just spray a little on the hinge (ideally with a small brush or a spray can with a fine nozzle) and then open and close the door several times. Usually, the squeaking settles down quickly after that.
If you don’t have WD-40 or similar on hand, regular sewing machine oil works too—it has the right viscosity for these small moving parts.
One more tip: hinges can also get sticky from dust or old oil residues, so if you have the time and patience, take the hinges off briefly, wipe them clean, and then lubricate again. But often just spraying them is enough.
Good luck bringing some quiet to the squeaking concert!
taudi
29 Dec 2021 09:18
I’m happy to add a brief guide on how to properly maintain Ikea Pax hinges:
- First, open the door and loosen the visible screws on the hinge so you can remove it (Warning: do not fully unscrew the screws, just loosen enough to detach the hinge).
- Carefully take out the hinge and clean it with a lint-free cloth. If there is dirt or old lubricant, wipe it with a little diluted dish soap and allow it to dry thoroughly.
- Then use a suitable lubricant. I recommend a non-sticky, thin oil (for example, sewing machine oil or specialized door hinge oils). Grease is not ideal as it tends to attract dust quickly.
- Apply the oil to all moving parts of the hinge, especially the pivot and spring mechanism.
- Reinstall the hinge, tightening the screws firmly but not too much to maintain smooth movement.
- Open and close the door several times to distribute the oil evenly.
Special note for Ikea Pax: since these hinges often have a damping function, be careful that the lubricant does not affect the damping element. Use it sparingly.
If you can specify the exact model (with a photo or detailed description), I can provide more tailored advice.
Summary:
- Remove the hinge
- Clean it
- Use thin oil
- Avoid excessive or greasy lubricants
- Test the door
This not only saves frustration but usually also extends the lifespan of the hinges.
FELOTAU
30 Dec 2021 16:22
taudi schrieb:
Carefully remove the hinge and clean it with a lint-free cloth.
Good tip! I had the same issue and was unsure at first whether I should completely remove the hinges. Cleaning is definitely the first step – for me, the squeaking improved significantly after cleaning and carefully applying a light oil.
I also want to add that patience during the process is important: after applying the oil, make sure to give it time to work and move the doors frequently.
I know it can be annoying, but applying too much or the wrong lubricant quickly can cause new problems, especially with fittings from hardware stores or IKEA, which are often precisely matched to the materials.
If you’re unsure, don’t hesitate to ask again – we’re here to help! I felt like I was working on an old clock mechanism myself but was very happy in the end that the cabinet now works without that annoying noise.
