ᐅ How do I fix squeaking noises in Billy cabinet doors?
Created on: 10 Jul 2015 18:37
Borosin
Borosin
10 Jul 2015 18:37
I have noticed that the doors on my Billy shelves squeak quite loudly when opening and closing. I suspect the issue is related to the hinges or their fittings, but I am unsure how to effectively and permanently fix the problem. Could someone provide a detailed guide on how to eliminate the squeaking noise on the Billy doors? I am especially interested in which tools or lubricants work best, whether it is necessary to remove the doors, and if the hinges might need to be replaced. I want to do the repair myself if possible and would appreciate tips and tricks to avoid common mistakes.
Fareo65
11 Jul 2015 08:21
Borosin schrieb:
How can I eliminate squeaking noises on Billy doors? I’m especially interested in which tools or lubricants work best
To eliminate squeaking on Billy doors, I recommend the following structured approach: first, remove the doors to access the hinges more easily. Then, apply a suitable lubricant to the hinges—silicone-based sprays are ideal because they don’t attract dirt or leave residues. An alternative is WD-40, but use it sparingly since it primarily displaces moisture rather than providing long-term lubrication.
You typically only need a Phillips screwdriver to loosen the hinges and a cloth to wipe off any excess lubricant. If the hinges are damaged or bent, replacement is advisable as repairs often don’t last. After lubricating, rehang the doors and open and close them several times to distribute the lubricant evenly. This method is effective and helps prevent recurring issues.
praWarre69
11 Jul 2015 12:04
Borosin schrieb:
I suspect the issue lies with the hinges or their mounting
You’re on the right track; hinges are usually the culprits when Billy-style doors start squeaking. 🙂 Here’s a tip: take your time when lubricating – too much won’t help, and too little means you’ll have to do it again unnecessarily.
Another helpful step is to tighten the hinge screws. Over time, screws can loosen, especially if the doors have been in place for a while, which can also cause noise. You can also apply a tiny drop of sewing machine oil or graphite spray to the hinges—these work really well for metal-on-metal contact.
And a little fun note: if you have cats at home, watch out that they don’t step on the freshly lubricated spots – the result will be not only squeak-free but also a paw print with grease marks 😉
EDWARD0
12 Jul 2015 10:52
Fareo65 schrieb:
Silicone-based sprays, as they do not cause dirt
Silicone spray is truly the best choice. Remove the doors, spray the hinges, wipe off any excess spray, rehang the doors. Open and close them to distribute the spray – done.
praWarre69 schrieb:
Tighten screws
Important: Always check for loose screws, this often helps faster than expected.
