ᐅ How can I fix squeaking noises in IKEA Metod drawers?
Created on: 16 Dec 2022 08:12
Simona
Hello everyone, I have a problem with my IKEA Metod kitchen drawers: they squeak every time they move, whether pulled gently or more firmly. It’s quite annoying, especially because it’s very loud and still persists after several weeks. I suspect it has to do with the sliding rails, but I’m not sure what the best and most permanent solution is. Does anyone know a good method to get rid of these squeaking noises? Should I use lubricants, remove the sliding rails, or are there special products from IKEA or third-party suppliers? I would appreciate any tips, especially if they are long-lasting and easy to apply.
sinhau
17 Dec 2022 08:26
Additional information:
If you still want to use replacement runners, it is essential to carefully measure the dimensions of the original runners and check for any necessary adjustments. Some manufacturers offer equivalent soft-close runners, which are usually of better quality. However, installing them often requires drilling new holes or making modifications, which can be problematic in rental apartments.
Summary:
- Start with cleaning and silicone spray
- Replace runners only if heavily worn, carefully checking compatibility
- Better soft-close options are available, but installation is more complex.
Simona
17 Dec 2022 09:45
Let me summarize what I have learned:
- Remove the drawers
- Clean the sliding mechanism with a damp cloth to remove dust and dirt
- Apply a thin layer of silicone spray to the metal parts, avoiding plastic components
- Reinsert the drawer and move it back and forth several times
If that doesn’t help, check whether the runners are damaged and replace them if necessary, although this can be quite labor-intensive.
Thanks to everyone for the helpful tips! I will try it out this weekend and report back.
Wesley
18 Dec 2022 10:15
Glad to hear the tips make sense! Let me know if you need any more help. The whole process usually goes quickly, and afterwards, there’s peaceful quiet in the kitchen. 😉
Simona
18 Dec 2022 19:03
A quick update from me: Cleaning and silicone spray helped a lot, the squeaking is almost completely gone! Thanks again to everyone. By the way, I removed the drawers first, which made the work much easier. I would definitely recommend that.
