I recently noticed that the joints on my IKEA Malm bed frame have become quite loose. The screws no longer hold firmly, and the whole frame wobbles noticeably, which is not only annoying over time but likely harmful to the bed as well. What would be the best way to tighten these loose connections again without damaging the material? I’m considering new screws, wood glue, possibly larger dowels, or special repair kits.
Additionally, I would like to know if it’s advisable to check and fully readjust all joints if necessary, or if targeted repairs are more effective. I already have some tools available, I’m somewhat technically experienced, but I don’t want to rush into anything. Thanks for your advice!
Very good and precise question.
For loose joints on the Malm bed frame, it is advisable to first check the existing screws and dowels. Often, the problem is caused by swollen material or worn dowel holes. In such cases, it is recommended to completely remove the screws and repair the holes slightly with wooden dowels and wood glue to restore the proper fit.
Another option is to use slightly thicker screws or special wood repair screws. It is important not to damage the original joints, especially if the furniture piece is still relatively new.
Targeted repairs are often sufficient, but if multiple joints are affected, a complete inspection of all connection points is worthwhile to ensure long-term stability.
Tarmau schrieb:
Completely removing the screws and lightly repairing the holes with wooden dowels and wood glueHmm, that sounds solid at first, but isn’t it sometimes overkill to fill every hole with dowels? IKEA furniture is usually designed for quick assembly, not complex repairs. Maybe just using a stronger screw and a bit of manual force is enough. Too much effort for something that isn’t even designer furniture.
To be honest, who really repairs that precisely? Most people just tighten screws again. I think this is overrated.
I understand both sides here. Especially with furniture you’ve assembled yourself, any wobbling can be quite annoying. I once had a bed where only a combination of some wood glue applied inside the holes and thicker new screws helped. Having confidence in the stability is important, after all, you don’t want to have the uneasy feeling at night that everything might collapse.
Gegla, if you’re unsure, I would recommend taking your time and approaching the repair carefully. It’s good that you’re addressing this now, otherwise the joints will probably get even worse.
Hello Gegla,
I want to give you a detailed tip since I often handle these kinds of repairs myself:
First, carefully disassemble the bed frame or at least fully loosen the loose joints to have a clean workspace. Then, check the screws for damage and replace them if necessary.
If the dowel holes are already worn out or too large, using wooden dowels with wood glue is the best solution. Make sure to position the dowels precisely so that the joints fit perfectly after reassembly.
Important: Let the wood glue cure for at least 24 hours after assembly before putting any load on the bed. This step ensures lasting stability.
If the material is swollen or damaged, you could prepare a mixture of some sandpaper and gently work on the connection points to achieve an even surface.
In addition to the mechanical repair, using clamps or furniture clamps while drying can help guarantee a firm hold.
I hope this helps! If you have any questions about the tools or suitable materials, feel free to ask.
