ᐅ How do I fix loose joints in MALM furniture?
Created on: 28 Oct 2024 08:42
pra-walter
Good morning everyone, I have several Malm furniture pieces (mostly dressers and similar items) in my home that, after a few years, have started to develop loose joints. This means that some drawers or connections wobble and are no longer properly stable. My specific question is: What is the best way to repair loose joints in Malm furniture? Which tools or materials are recommended to restore stability without damaging the piece? Are there any special techniques to securely tighten the joints again, possibly including tips for worn threads or stuck wooden parts? I look forward to your advice, as I don’t want to throw away the furniture or replace it with a costly alternative.
blapau
29 Oct 2024 07:33
Regarding the tips about replacement sleeves and wood glue, I would like to add that Malm drawers often have issues with the side rails slipping or no longer fitting properly in the guides. It is worthwhile to check all metal slides for dirt or bent parts. Cleaning them with a dry cloth and slight readjustment can make a big difference.
In addition, I have had good experience using self-adhesive foam strips as spacers in joint holes where screws are loose. This prevents renewed wobbling and is reversible.
Davidleo
29 Oct 2024 14:56
Wow, so many useful tips here! 🙂
I simply checked and tightened all the screws on my MALM dressers. That immediately made a difference—really great!
And thanks for the tip about the replacement tension sleeves; I’ll order those right away – that hadn’t even occurred to me before.
For anyone still unsure, you can do this, don’t worry! Patience when replacing parts is important, and in the end, you’ll be happy to have stable furniture. Good luck to everyone, you’ve got this! :-)
