ᐅ How can I secure Ikea PLATSA doors to prevent them from swinging?
Created on: 25 Nov 2024 08:17
Tujobo
Tujobo
25 Nov 2024 08:17
Hello everyone, I am facing the following issue: I bought the Platsa system from Ikea and installed the doors, but when opening or closing them, they sometimes swing noticeably. This is especially noticeable with the larger doors, which is not only visually distracting but also somewhat annoying in daily use. My question is: How can I secure or possibly retrofit the Ikea PLATSA doors so that they no longer swing and close firmly? Are there any proven tips or perhaps special mechanisms or dampers that I can install additionally? I would like to work with the original hinges but am open to additions that require little effort. Thanks in advance for your help!
Jensson
25 Nov 2024 09:22
Hello Tujobo, your question is very well formulated, and I can clearly understand the issue with the swinging PLATSA doors. Here is a brief step-by-step guide to help you manage the problem:
- First, check if all hinges are correctly and securely installed. Screws can often loosen slightly, causing play.
- Use the adjustment options on the hinges: Ikea PLATSA hinges typically have settings for depth, height, and lateral alignment. Precise adjustment often results in a firm fit.
- To prevent swinging at the end of the closing process, door dampers can help. Ikea does not offer specific dampers for PLATSA doors, but universal door dampers or soft-close mechanisms that can be retrofitted are an option.
- Some users also recommend using magnetic catches as a pulling element that draws the door toward the cabinet body, thereby reducing swinging.
Summary: Before purchasing expensive additional products, you should check and precisely adjust the hinges. Afterwards, you can add dampers, magnetic catches, or rubber buffers. If you have any questions about adjustments or suitable dampers, just reach out here.
flo-Theres
25 Nov 2024 12:37
Jensson schrieb:
Use the adjustment options on the hinges: Ikea PLATSA hinges usually offer settings for depth, height, and lateral movement.
This is exactly the most important point. Many often underestimate that hinges are not just for hanging the door but allow precise adjustments. I recommend:
- Remove the door completely first
- Then loosen all the hinge screws, rehang the door, and slowly tighten the screws while adjusting
- Make sure the door always fits tightly against the cabinet without binding
Swaying usually results from too much play or a slight gap, which can be reduced through mechanical adjustment. If a soft-close mechanism is missing, you can retrofit it separately. This is usually the cleanest and most durable solution.
Paunon
26 Nov 2024 07:04
I had the same issue. What helped me was adding a small washer as a spacer at the bottom hinge. This causes the door to fit slightly tighter and prevents it from swinging back.
koduga
26 Nov 2024 10:53
Paunon schrieb:
For me, it helped to insert a small washer as a spacer at the bottom hinge.
That sounds like a simple yet clever solution! Thanks for sharing. Sometimes it's exactly these small tricks that you expect but don't know about. Especially when you see the problem and think the doors should fit perfectly from the start, but they don’t — it can make you feel uncertain. It’s reassuring to know that such a small adjustment can significantly reduce swinging. Perhaps someone who isn’t comfortable with dampers might want to try this? How was your experience with the installation — has it proven to be a lasting fix?
