ᐅ How do I repair dents on Malm surfaces?
Created on: 26 Feb 2021 18:07
blerjan
blerjan
26 Feb 2021 18:07
I have a problem with some small dents on the surface of my Ikea Malm bed. These pieces of furniture are usually sealed with a lacquer or a foil that can be quite sensitive. My specific question is: How can I properly repair dents on Malm surfaces without damaging the finish or making the repaired spots noticeably stand out?
I am looking for a method that is easy for beginners to carry out, ideally using materials that are easy to obtain. Maybe someone also has tips on surface preparation or special products that have proven effective?
I would appreciate it if you could share your experiences or well-founded advice.
Donar34
26 Feb 2021 19:23
Care should be taken with dents in Malm surfaces, as they often have a plastic or melamine coating that can be easily damaged if handled improperly.
A systematic approach is as follows:
1. Clean the area with a mild detergent to remove dirt.
2. Use a special wood filler or putty that matches the color of the surface. These can be found at hardware stores.
3. Carefully apply the filler with a spatula to fill the dent.
4. After drying, use very fine sandpaper (e.g., grit 400-600) to smooth the area.
5. Finally, touch up the spot with a matching paint pen or clear lacquer.
This procedure preserves the appearance and prevents the spots from becoming noticeable later.
Important: Avoid extreme moisture or heat (such as steaming) on melamine surfaces, as they can cause the surface to swell.
Nauman5
26 Feb 2021 21:07
Hey blerjan,
small dents on Malm surfaces are definitely not ideal, but don’t stress out! 🙂 Often, a bit of wood filler and some patience are enough to make your furniture look good as new.
A handy tip I once read: For very small dents, you can try gently warming the area with a hairdryer and then lightly massaging the surface with a very soft cloth. Sometimes this helps to “raise” the dent a little.
But be careful: don’t overheat it, as you might damage the melamine coating!
Otherwise, wood filler, sandpaper, and a matching touch-up marker are your best friends. And hey, if you’re not ready for big repairs right away, try it first in an inconspicuous spot. Good luck! 😉
CORYGAU
27 Feb 2021 09:31
Donar34 schrieb:
Use of a special wood filler or putty that matches the color of the surface.
This is basically a good tip. However, I wonder if using wood filler on melamine surfaces might actually be less than ideal. Melamine is a plastic coating that does not interact with wood materials. In such cases, filling with traditional wood filler can lead to cracking or chipping.
Has anyone had experience with special repair kits specifically designed for Ikea furniture with melamine or laminate surfaces? Traditional wood repair products might actually be counterproductive, even if they appear to be a “matching” solution.
Nauman5 schrieb:
warming it with a hairdryer and then gently massaging the surface with a very soft cloth
Interesting approach, but how exactly does this help in restoring the dent? Perhaps the brief heat softens the material? Please clarify.
RON57
27 Feb 2021 11:46
Good morning everyone,
I’d like to share my thoughts on the topic of dents in IKEA Malm furniture, as I have dealt with this issue several times before.
First of all: The Malm series usually has a melamine resin-coated surface, which means it is very resistant to water but sensitive to mechanical damage such as dents.
Regarding repairs:
- Small dents can be fixed quite well with special repair waxes that are available in different colors for furniture surfaces. You warm the wax slightly and press it into the dent, then smooth it out with a spatula.
- For deeper dents, I actually recommend, as Donar34 suggested, filling them first with a suitable filler. However, I don’t use wood filler but a plastic-based one. These materials can be found at well-stocked building supply stores or in IKEA repair kits.
- After filling and smoothing, a touch-up marker (IKEA offers several shades) helps to color match the area.
It is important to keep the surface clean and grease-free before repair and to allow the repair materials to dry thoroughly. If you have any questions, feel free to ask—I’ve done this several times already. 🙂
nofomu
27 Feb 2021 14:12
Dents on Malm surfaces are best repaired as follows:
1. Clean the surface
2. Use plastic filler (not wood filler)
3. Sand smooth (fine sandpaper)
4. Touch up with a color-matched paint pen
Using a hairdryer or heat is ineffective and can damage the surface.
