ᐅ How do I fix stripped screws in IKEA PLATSA units?
Created on: 19 Mar 2021 08:17
Giapo
Giapo
19 Mar 2021 08:17
Hello everyone, I have a problem with my IKEA Platsa system where some of the screws in the wood or connection points seem to be stripped or damaged. More specifically, the screws no longer hold securely because the wood threads are worn out. As a result, the shelf loses stability. My question is: Are there any proven methods or tricks to repair damaged screws or their fastening in IKEA Platsa without having to replace the entire wooden part? I am thinking of special repair kits, wood fillers, or possibly replacement parts from IKEA. It is important to me that the solution is not too complicated, lasts as long as possible, and allows me to continue using the shelf safely. I appreciate any tips as well as warnings about incorrect approaches!
Daledra
19 Mar 2021 08:45
If the thread in the wood is stripped, inserting hardwood dowels or toothpicks into the hole, then adding wood glue before screwing the screw back in, often helps. This way, the wood regains a better grip.
REPITAR
19 Mar 2021 09:32
Hello Giapo,
I’d like to explain a proven method to repair stripped screw holes in PLATSA furniture:
- Step 1: Carefully remove the screw.
- Step 2: Fill the screw hole with small wooden sticks, toothpicks, or wooden filler pieces that fit well into the hole.
- Step 3: Use wood glue to stabilize the filling material.
- Step 4: Let the wood glue set briefly, then slowly and straightly screw the screw back in.
It is important not to let the glue dry completely before screwing in, as the connection should be fairly tight.
If the wood is completely damaged, you can also insert repair sleeves (dowels) or request replacement connectors from IKEA.
Summary: A mix of well-fitting filler material + wood glue + careful screwing usually holds strong and is easy to do.
Giapo
19 Mar 2021 10:27
Daledra schrieb:
If the wood threads are stripped, it often helps to insert hardwood sticks or toothpicks into the hole, then add wood glue and screw the screw back in. This way, the wood regains better grip.
Thanks for the tip. Is this solution durable? Especially with PLATSA, which can be loaded quite heavily, I want to avoid any risk of failure.
REPITAR schrieb:
If the wood is completely damaged, you can also use repair sleeves (dowels) or request replacement connectors from IKEA.
Which repair sleeves do you mean exactly? I would appreciate a more detailed explanation.
Liduta
19 Mar 2021 11:43
Regarding repair sleeves or repair anchors: these are used when the original screw hole is completely damaged.
The principle:
- You slightly enlarge the damaged hole so it fits the repair anchor.
- New internal threads are created inside the anchor that match the original screws exactly.
- Then you insert the anchor into the hole and can tighten the screw as usual.
These sleeves are usually made of metal or sturdy plastic and restore a secure fastening.
For IKEA PLATSA, you should make sure the repair anchors match the diameter of the original fasteners. Spare parts for IKEA furniture can sometimes be requested directly from IKEA, but repair sleeves are not always available as a separate product.
Alternatively, robust wood repair kits that use this technique are also recommended.
For stability, such repairs are considered very reliable when done carefully.
Daledra
19 Mar 2021 13:02
Repairs using wooden strips and glue hold well on IKEA furniture, especially if the screw is not frequently removed. For shelves like PLATSA, I usually use the wooden glue-toothpick method, which is usually sufficient.
