Hello everyone, I have an Ikea Brimnes cabinet that has been quite wobbly for some time now. The stability is clearly lacking, especially when I open the doors or lightly touch the cabinet. I suspect the issue is with the connections between the individual panels, possibly loose screws or missing reinforcements. Since I assembled the cabinet myself, I now want to fix the wobbling in a targeted and permanent way without having to take everything apart completely. Does anyone have experience with this specific model and can provide a practical guide on which screws should be checked first, how to effectively reinforce the back panel, and whether additional measures like dowels or brackets might help? I look forward to tips that also address the typical weak points of the Brimnes—preferably with advice on where to start to solve the problem precisely and permanently.
The most common cause with the Ikea Brimnes is loose screws on the side panels and the back panel. First, tighten all screws properly. If the back panel does not sit completely flat, it often helps to reattach it to make the cabinet more stable. Additionally, it can be useful to anchor the cabinet to the wall if possible.
I would like to go into more detail about the issue, as the Brimnes wardrobe has some common weaknesses that can cause it to wobble. First, it is important to approach the problem systematically:
- Screw check: All internal connection screws (especially the large cam bolts) must be tightened close to the recommended torque. It is important not to overtighten in order to avoid damaging the material.
- Back panel: The thin hardboard at the back provides stability. If the back panel is not perfectly flat, the wardrobe will tilt when moved. The back panel must be fully stretched; if screws are missing or the metal clips are loose, those should be added or tightened.
- Base and standing surface: Check whether the wardrobe sits level—often, an uneven floor can increase wobbling. Foam pads under the feet or adjustable feet screws can be very helpful here.
- Wall fastening: It is advisable to use the supplied safety kits that secure the wardrobe to the wall. This is especially important for tall models like the Brimnes, both for stability and safety reasons.
- Improvements: Some users report that adding additional brackets or self-adhesive reinforcements on the edges significantly increases the rigidity of the wardrobe. When using wall plugs (anchors), one should be careful not to damage the original building structure.
As a tip: Test the screws and the back panel first before adding extra parts. If you need a detailed guide, I can gladly provide a summary.
Filippo schrieb:
First of all, it’s important to approach this systematically:This is a very helpful approach. Especially with furniture like the Brimnes, it is important to proceed step by step to effectively eliminate any wobbling.
As an addition: Wobbling is often caused by minor inaccuracies during assembly, which can be fixed by tightening the connections. Also, make sure to check that all wooden parts are straight, as this issue is sometimes noticed too late.
Another tip: If you completely empty the wardrobe and then check and tighten the screws one by one, you can identify potential stress points. This way, you avoid unnecessarily unscrewing parts that are not affected.
Furthermore, I definitely recommend using the wall anchoring. In many cases, it is crucial for stability, especially if the wardrobe is relatively tall.
Eymenleo schrieb:
Does anyone have experience with this specific model and can provide a practical guide on which screws to check first, how to effectively reinforce the back panel, and whether additional measures like wall plugs or brackets might help?Start by checking the screws on the side and bottom panels. Then inspect the back panel – often, replacing screws or nails helps. Brackets can be added later for extra stability, especially at the corners. Wall plugs are rarely necessary unless the holes have worn out.
