Hello everyone, I have a problem with a loose IKEA Metod drawer that keeps loosening and wobbling when I pull it out or push it in. It is a standard kitchen drawer running on side-mount rails, but the front panel no longer seems to be firmly attached to the cabinet. The screws are tightened, but the drawer still wobbles – I suspect that the wood or the joint may be damaged. What is the best way to fix this loose connection without having to replace the entire drawer? Are there any proven tips or specific replacement parts available for the Metod series? Any help would be greatly appreciated!
sinija schrieb:
I have a problem with a loose IKEA Metod drawer that keeps loosening and wobbling whenever I pull it out or push it back in.Hello! I know that all too well – those small movements often cause a lot of frustration. From my experience, the problem usually lies with the front attachments loosening over time. My advice would be to systematically loosen all screws and then retighten them firmly, including those on the hinges and the drawer front.
If the wood around the screw holes is already a bit worn out, you can fill the hole with small wooden wedges or toothpick pieces before reinserting the screw. This will help restore a solid hold.
Just a little tip: if you have a bit of patience, this often works better than assembling a new piece of furniture 😉
The cause of wobbling in IKEA Metod drawers is in most cases due to the attachment points of the front panel or the bending of the side rails. A proper diagnosis is as follows:
- Check that screws are securely tightened
- Inspect wooden joints for fraying
- Check plastic or metal parts of the sliding rails
If the screw holes are worn out, it is recommended to fill them with wood glue mixed with sawdust or small wood chips, then allow sufficient drying time before reinserting the screws. This ensures greater stability.
A completely new drawer is only necessary if the sliding rails themselves are damaged or bent; otherwise, repair is sensible and cost-effective.
Dustin schrieb:
First, check if the screws on the front panel are really tight.Thanks, that was my first step. All the screws on the inside are indeed tight, but there is still some wobbling.
meGreg schrieb:
If the wood around the screw holes is already a bit worn out, you can fill the holes with small wooden wedges or toothpick piecesI haven’t tried that yet, but it sounds like a good idea. My problem is that the joint between the front and the carcass doesn’t feel very “solid,” and I suspect the wood may have given way in some places.
Is there a particular type of wood glue or technique to best secure the wedges so that it holds permanently? I’d appreciate it if someone with experience could share their advice.
It is best to use wood glue that is waterproof and fast-drying. Press leftover pieces of toothpicks or small wooden sticks into the screw holes, then apply glue, let it dry briefly, and then insert the screw. Important: Do not tighten the screw too much, otherwise the wood will split again.
