Hello everyone, I’m looking for advice on the optimal placement of Malm beds in bedrooms.
Specifically, I’m interested in which factors to consider when positioning the bed to make the most efficient use of the space while ensuring frequent use and maximum comfort.
Are there any recommendations regarding window placement, distance from walls, effects of lighting conditions, or even ergonomic aspects when choosing the spot? I have a rather small bedroom (about 12sqm (130 sq ft)) and want to avoid the bed overwhelming the room or making storage under the Malm bed inconvenient.
How do you find the perfect spot for Malm beds without neglecting other furniture and walkways? What mistakes have you made in positioning, and what did you learn from them? Thanks in advance for your experiences and tips!
A structured approach can be helpful:
1. Distance from the wall: At least 10 cm (4 inches) on all sides if the bed has drawers, to allow them to open easily.
2. Lighting conditions: Avoid placing the bed directly next to west- or south-facing windows, as strong direct light can disrupt sleep.
3. Room function: Position the bed so that access to the room is easy without blocking the hallway.
4. Ergonomics: If possible, the headboard should be against a solid wall to provide a sense of security.
5. Storage space: The Malm drawers require at least 30 cm (12 inches) of clearance in front of the bed for opening.
A common mistake is placing the bed directly under a window while neglecting the drawer space, which makes use difficult.
Regarding the perfect placement of Malm beds, I would like to add some technical details:
First, it is important to take precise room measurements and create a simple grid that also includes doors and windows. Malm beds are available starting at a height of approximately 30 cm (12 inches) for the drawer frame, with drawer heights around 20 cm (8 inches).
The following aspects are crucial:
- Ventilation: Since Malm beds are often made of wood, air circulation under the bed should not be too restricted. Direct contact with cold exterior walls can lead to condensation.
- Drawer mechanism: This requires at least 70 cm (28 inches) of clearance in front of the bed to be fully opened. Without this space, the drawers can only be partially used.
- Light reflection: Placing the bed opposite a window can result in strong morning sunlight, which may be disturbing and require blackout measures.
Therefore, my suggestion is to use a room sketch before making a final decision and to take a third set of measurements during the surveying process to rule out inaccuracies.
It is still unclear whether your bedroom has alcoves or sloping ceilings that could be used as placement areas?
KAULIS schrieb:
A common source of problems is often placing the bed directly under a windowThat’s an interesting observation, thank you for that. My room actually has a large east-facing window, and I have been considering placing the bed there so far.
Filippo schrieb:
It is still unclear whether your bedroom has alcoves or sloping ceilingsThe room has two walls without slopes; the others are standard. There are no alcoves.
The tip about air circulation under the bed is new to me—I haven’t considered potential condensation issues before. Is there a general rule of thumb about the best distance from the external wall? I have the option to place the bed either on the internal wall or the external wall. Which position would you prefer?
As someone who writes extensively about sofa beds, here is a brief guide to the ideal placement of a Malm bed in the bedroom:
1. Wall positioning: The headboard should be against a solid wall to ensure stability and a sense of security. However, the wall should not be too cold to avoid condensation.
2. Windows: Ideally, place the bed so it is not directly under a window to prevent drafts and light disturbances.
3. Clearance space: Allow at least 60 cm (24 inches) in front of the bed for the opened bed frame or the drawers. If you only have 50 cm (20 inches), you will quickly face limitations.
4. Keep storage accessible: Especially with Malm beds, the drawer pull-out function is essential. Avoid placing other furniture doors where they could block access.
5. Radiators: Try not to position the bed directly in front of radiators, as this can reduce sleeping comfort.
A common mistake in small bedrooms is to squeeze the bed too much into a corner, which then restricts the drawer function.
Conclusion: Unobstructed drawer access combined with optimal distance from windows and doors offers maximum comfort and practical use. Good luck with your setup!
