ᐅ How can I find suitable mattresses for Ikea Hemnes beds?
Created on: 25 Jun 2019 08:42
PEOPI
PEOPI
25 Jun 2019 08:42
Hello everyone, I’m looking for recommendations and experiences on how to find suitable mattresses for IKEA Hemnes beds.
I understand that Hemnes beds come in different sizes (such as 90x200cm (35x79 inches) or 140x200cm (55x79 inches)), but what I’m particularly interested in is how to determine the perfect mattress height and firmness that fits well on the Hemnes bed slatted base while providing enough comfort and support.
Also, I’m wondering if there are any limitations regarding mattress types (foam, latex, innerspring, etc.) due to the bed’s construction or support surfaces. Are there any mattress models that work especially well or poorly in this context?
Additionally, are there practical tips on where to find affordable but good quality mattresses that match these beds?
I look forward to your advice!
korosu
25 Jun 2019 09:07
Basically, Hemnes beds use slatted bed bases with standard sizes, namely 90x200 cm (35x79 inches) or 140x200 cm (55x79 inches). You should choose a mattress that matches these exact dimensions to prevent it from shifting.
The firmness depends on your sleeping habits; there are no specific restrictions. Both foam mattresses and innerspring mattresses work. Just make sure the mattress isn’t too thick, as this could make the bed frame tight.
Kinbu
26 Jun 2019 14:23
Hello PEOPI, I can understand your question well, as choosing the right mattress is often complex. Regarding the Hemnes bed: the frame is sturdy, but the slatted base plays an important role.
- First, you should check whether your slatted base has suspension and how wide the slats are. This affects the comfort and support.
- The mattress height for Hemnes beds is usually flexible – you can generally use mattresses between 15 and 25 cm (6 and 10 inches). Thicker mattresses can affect the appearance or make getting in and out more difficult.
- There are no technical restrictions on the type of mattress, but with a slatted base, a flexible mattress like memory foam or latex is usually recommended, as spring mattresses sometimes do not provide as comfortable a sleeping experience.
When choosing, especially at IKEA, you can find mattresses in different price ranges that fit well with the Hemnes. Make sure the mattress is breathable to prevent moisture buildup. If you replace the slatted base yourself, there are also sturdy models that work better with certain mattresses.
I hope this helps!
Donar34
27 Jun 2019 11:19
To choose the right mattress for IKEA Hemnes beds, I recommend closely following the bed model’s exact dimensions.
The Hemnes bed series uses standardized slatted bed bases for mattress sizes such as 90x200, 140x200, or 160x200 cm (35x79, 55x79, or 63x79 inches). Mattresses must match these dimensions precisely to avoid damage to the bed frame or slatted base.
Regarding mattress height, a maximum thickness of about 20 cm (8 inches) should not be exceeded for Hemnes beds, as a taller mattress can make the headboard look out of proportion and increase the bed’s overall height, making it harder to get in and out.
About mattress types: spring mattresses are acceptable if the slatted base provides sufficient support; however, for the Hemnes series slatted bases, mattresses made of flexible materials like cold foam or latex are generally recommended to prevent deformation.
Additionally, mattresses with good ventilation are particularly useful since the Hemnes bed frame features partially closed sides that limit airflow.
In summary: check the dimensions carefully, choose a flexible and breathable mattress, and keep the mattress height to a maximum of 20 cm (8 inches).
RETRAVIS
28 Jun 2019 16:01
Donar34 schrieb:
The mattresses must meet these exact dimensions to avoid damage to the bed frame or slatted base.
This is a very important point. Additionally, the mattress must not only fit the width and length but also be compatible with the slatted base.
IKEA Hemnes beds typically come with slatted bases that use flexible slats. These should not be combined with overly rigid mattresses, as this would reduce their effectiveness.
Kinbu schrieb:
There are no technical restrictions regarding mattress type, but a flexible mattress like memory foam or latex is generally recommended for slatted bases,
Exactly, flexible mattresses work better with slatted bases featuring flexible slats, offering better point elasticity and improving sleeping comfort. The mattress height should be between 15 and 20 centimeters (6 and 8 inches) to ensure the bed’s protection and stability.
It is also advisable to choose breathable materials to promote ventilation. This is especially important for Hemnes beds because the slatted base does not provide direct airflow through a fully open frame.
Regarding the purchase, buying directly from IKEA is often convenient, but it is also worth checking compatible models at specialist retailers.
