ᐅ How can I equip IKEA Besta units with casters for greater flexibility?
Created on: 12 Jun 2023 08:37
KajarleHello everyone,
I plan to equip my IKEA Besta shelving unit with casters to make it more flexible and mobile within the room. I don’t want to just attach any caster; I’m looking for a stable and durable solution that matches the Besta design aesthetically and is also functional—meaning smooth-rolling, lockable, and robust enough for regular use.
What types of casters are recommended for the material and construction of Besta furniture? Do I need special screws or mounting plates to securely attach the casters? Are there any proven models or experiences with suitable caster sets? I’m also interested in how much additional height the casters add and whether stability is noticeably affected by them.
I appreciate any practical tips, manufacturer suggestions, or personal experiences to help me make the right choice. Thanks in advance!
Hello Kajarle,
Your question is very well structured, which makes giving recommendations much easier. First of all: The IKEA Besta is usually made of medium-density fiberboard (MDF) with a foil-coated surface, which means that attaching casters needs to be carefully planned to ensure stability.
For a practical solution, I recommend using furniture casters with a mounted fixing plate. These casters have a square metal plate that is attached with four screws. This is much stronger than casters with threaded stems that screw directly into a pre-drilled hole in the wood.
- Dimensions: Make sure the base plate is at least 50x50 mm (2x2 inches) to distribute the load well.
- Screws: It’s best to use screws at least 4 mm (5/32 inch) thick and about 25-30 mm (1-1.2 inches) long. Pre-drilling with a 3 mm (1/8 inch) drill bit is recommended to prevent the MDF from splitting.
- Caster height: Standard caster height ranges between 50-75 mm (2-3 inches), which means roughly 5-7.5 cm (2-3 inches) of lift. This can noticeably change the overall height of your Besta unit, so make sure the doors can still close properly.
I would advise measuring the height beforehand and checking if the casters have locking brakes, especially if you plan to move the Besta frequently. This prevents unwanted rolling.
Question: How much weight will the Besta be carrying in daily use? Do you want it to be a lightly movable item or a permanently flexible solution?
In summary: Use casters with fixing plates, sized adequately, pre-drill, and choose the screws carefully. Assembly is quite manageable with a bit of DIY skill.
I can also provide specific product recommendations if you like.
bapar schrieb:
For a practical solution, I recommend using so-called furniture casters with a mounted fixing plate.This recommendation is correct and should be considered standard if you want to make the Besta shelving unit permanently movable. I would like to add the following:
- The load capacity of the casters should be at least 15-20 kg (33-44 lbs) per caster to safely support heavy contents.
- Check if the casters have a soft tread surface (e.g., TPE or rubber) to prevent floor damage and reduce noise.
- Casters with a locking brake are essential if you want to fix the furniture in place occasionally.
- When drilling, apply only light pressure as MDF is prone to splintering. Depending on the thickness, you can also install a small wooden plate or washer inside the furniture to increase stability.
Installation is ideally done on the lower edges of the side panels—often at the bottom inside or outside if there are no doors or flaps in the way.
The technical modification can be easily completed with basic tools (drill, screwdriver, protractor). If you want to move the Besta unit flexibly, I also recommend choosing casters that add minimal height and do not unnecessarily increase the overall height.
If you need further assistance, I am available to help.
Kajarle schrieb:
Which types of casters are recommended for the materials and construction of Besta furniture?To answer this question in more detail: The construction of Besta, with its carcass made from laminated MDF panels, requires casters that are designed not only for load capacity but also carefully matched to the type of mounting. A mounting flange that is too narrow can cause material breakage.
Specifically:
- Choose casters with a mounting plate of at least 5x5 cm (2x2 inches).
- Use countersunk screws so they sit flush and prevent edges that could catch on the floor.
- To avoid damaging the supporting side panels, optionally use small wooden reinforcements (e.g., custom-cut plywood plates) as backing plates between the furniture and the caster.
bapar schrieb:
It’s best to use Spax screws that are at least 4 mm thick and about 25-30 mm (1-1¼ inches) long. That is appropriate. Make sure to control the torque when tightening the screws, as MDF can tear out easily.
Also, you should match the caster wheel diameters (usually 50 mm or 75 mm (2 or 3 inches)) to your use case: Larger wheels move more easily over carpets but will increase the total height.
Regarding the load: Plan for at least 80-100 kg (175-220 lbs) total weight including contents, so the casters and fittings won’t be overloaded.
Finally, on the aesthetics: Black casters with a matte-coated base plate usually blend well with Besta’s standard design. If you prefer a sleeker look, there are also low-profile design casters available.
If you need recommendations for caster types or models, I can gladly provide a list of reliable furniture casters that have proven effective.
