ᐅ How can I ensure that IKEA PLATSA doors close flush?
Created on: 27 Sep 2023 10:07
lautau
Hello everyone, I recently bought an IKEA PLATSA cabinet system and am now installing the doors. I noticed that the doors do not close flush; instead, they sometimes overlap or small gaps remain visible. I’m wondering how to ensure that the IKEA PLATSA doors close properly and are neatly aligned. What adjustments are possible on the hinges, and what else should I pay attention to during installation? I’ve read that small adjustments can help, but I would like to know if there is a step-by-step guide or proven tips to fix the issue permanently. Thanks in advance for your advice!
V
vinpau
28 Sep 2023 09:34
Hey, I had the same issue with my Platsa, and after two hours of adjusting the hinges, everything was perfect! 🙂 The key is to really take your time and test each screw step-by-step.
What helped me the most:
- First, leave all the door screws quite loose
- Then hang the doors
- Gently adjust the height with the screws, sometimes even remove the door completely and rehanging it
- Carefully adjust the side alignment to ensure the gaps are even
- Finally, adjust the depth so the doors sit flush with the front of the cabinet
Be patient, the feel for the adjustments comes naturally. After that, the doors will seem to slide in effortlessly. Good luck!!!
eldubi
28 Sep 2023 11:52
In any case, align the cabinet body before installation. Then adjust the doors using the three screws. Check the magnetic catches. After that, the doors are usually flush.
SONLIS
29 Sep 2023 08:13
karlau schrieb:
If you want a flush-fitting piece of furniture with exact gap sizes, there are rarely solutions without some adjustments – maybe sanding, fine-tuning, or even buying different hinges.
That sums it up well. In the professional field, adjustable hinges are often used, which offer more tolerance than the standard options from IKEA.
Curtis schrieb:
Therefore, I would first check whether all wooden or MDF parts are straight and free of warping before spending too much time on screw adjustments.
Exactly, if the carcass is twisted, even the best hinge won’t help.
Another option: If you are handy, you can replace the hinges. This gives you more adjustment options and allows for a flush fit.
In conclusion, precise adjustment does take time but can be achieved quite well with some patience.
