Hello everyone, I have a question about repairing a loose IKEA Metod drawer and would appreciate efficient solutions.
The problem is that the drawer no longer fits properly; it has lateral play and wobbles when being pulled out or closed. The drawer slides do not seem to be damaged, but the screws are no longer very tight, which is probably due to repeated stress.
I am especially interested in how to make this drawer stable again as quickly and permanently as possible, which tools and materials are best to use, and if there are any tips to avoid having to readjust it in the future.
I would be grateful for any detailed advice, especially if you have experience with similar IKEA Metod systems. Tips on proper screw tightening or checking the drawer slides are also welcome. Thanks in advance!
Z
zarJody6819 Apr 2022 13:18jobar schrieb:
Is there a risk with this method that the screws could be over-tightened and damage the plastic of the drawer slides if I apply too much force?Yes, that risk exists. The plastic guides are not designed for high torque. It is recommended to tighten the screws only hand-tight — enough to hold them securely without putting unnecessary pressure on the material.
Regular checks, approximately every six months, are advisable because the material can deform over time. Also watch for signs of wear on the plastic guides. Repair or replace them as needed.
It is also a good idea to fully remove the drawer when inspecting, to clean out any dirt or foreign objects that could cause wobbling.
zarJody68 schrieb:
It is advisable to tighten screws only by hand, just enough to hold them securely without putting unnecessary pressure on the material.That’s exactly the right approach. I sometimes use a torque wrench to make sure I don’t overtighten, but that’s more of a luxury for the DIY sector.
While we’re on the topic, I’d like to add that using metal washers between the screw head and the wood can be helpful when working with soft materials. This helps distribute the pressure more evenly and makes loosening less likely by allowing for a better grip.
And if the wood is already somewhat damaged, wood shavings or small wood pieces combined with wood glue make for an inexpensive and effective repair option.
One last tip: If all fasteners have been checked and there is still play, it can help to align the drawer and properly adjust the slides. Sometimes the slides are slightly misaligned, which causes wobbling.
Also, clean the roller bearings, as dirt can cause them to jam. Often, the repair consists of thoroughly cleaning everything, correctly reinstalling the screws, and carefully readjusting with some patience.
