I am planning to install the IKEA Platsa system in a very small room and am looking for efficient assembly tips specifically tailored to limited space conditions. My room is quite compact, with a floor area of about 2.5 x 2.5 meters (8.2 x 8.2 feet), so making use of vertical space is especially important. I want to both maximize storage and ensure easy accessibility as well as a visually appealing organization.
I am particularly interested in recommendations for assembling the individual modules: What is the best way to combine open shelves and closed cabinets to avoid dust while maintaining a sense of openness? Are there clever tricks for mounting on narrow walls or in corners? Which installation aids (e.g., angle brackets, connectors) are especially useful when space is limited?
The interior layout and possible adjustments or expansions with additional elements would also be of interest.
If anyone has experience using Platsa in very small rooms, I would appreciate your suggestions. Thank you in advance!
Hello Buplo,
First of all, a clear and well-expressed request! Platsa is very flexible, and especially in small spaces, you can get a lot out of it with smart planning.
I want to go into more detail about the construction because in tight spaces, I recommend the following steps:
- Plan the vertical layout so that the heavier and frequently used compartments are positioned at the bottom. This ensures stability and ease of access.
- For very narrow areas, the use of corner and wall brackets is essential. They help to securely fix the modules and prevent tipping. Although IKEA offers some parts, it’s often worth visiting a hardware store for angle brackets with screws, which you can better adjust at an angle.
- You can use closed elements and drawers to keep out dust, but if space is limited, avoid too many doors that require clearance when opened. Unfortunately, Platsa doesn’t have sliding doors, but smaller doors with soft-close are a plus.
- Modular internal divisions: Use extra shelves or boxes supported by the system to reduce unused space and organize efficiently. It’s worth looking for storage accessories within Platsa, such as baskets and inserts, which help structure the interior space.
- Assembly: Especially in small rooms, mark every step in advance — use painter’s tape to visualize where the carcass will go. This helps avoid unnecessary repositioning.
My question: Do you have a specific corner or wall that is particularly narrow? That helps to give more targeted advice regarding modules and brackets.
Hope this helps!
Hope this helps!
Dilen schrieb:
You can consider closed elements and drawers from a dust perspective, but if space is limited, avoid too many doors that require clearance when opened.I’d like to build on that: I had exactly the same concern, Buplo, with a small apartment and a narrow room. At first, I was quite stressed because everything felt so tight, and I wasn’t sure how to arrange the modular units optimally.
A tip from my own experience: try to assign doors to the least frequently used compartments, and use open shelves or drawers for the main access areas. This not only makes the space more livable but also feels larger.
And one more thing about assembly: don’t worry if it’s a bit rough at the start. What helped me was laying out all screws, dowels, and parts by type before assembling—that saves a lot of time and frustration.
Also, if possible, work with a second person. Especially in narrow rooms, it can quickly become stressful to handle or adjust everything alone.
What also helps is flexibly adjusting the interior shelves. If you want to store many different items, experiment with the shelf heights before final screwing. This way, everything fits better—and the space doesn’t feel too cramped.
koduga schrieb:
At first, I was quite stressed because the space was so tight, and I didn’t know how to arrange the Platsa units optimally.Thank you for your honest insight; that really reassures me! In fact, there is a corner in the room that is only about 60cm (24 inches) wide, where I want to install a slim unit.
Dilen schrieb:
Do you have a specific corner or wall that is particularly narrow?Exactly, that’s the spot I’m uncertain about. I’m considering installing an open unit on the left and a closed one on the right, so I can secure both firmly to the wall together.
Do you have any experience fixing several Platsa modules side by side in narrow corners? Would you recommend using a corner brace, or is the original IKEA mounting hardware sufficient?
One more question regarding interior organization: For small spaces in general, is there a recommended balance of storage types (e.g., 70% drawers, 30% shelves), or does that always depend heavily on the intended use?
