ᐅ How can I effectively clean the glass surfaces of Ikea Pax wardrobes?
Created on: 23 Jan 2022 14:07
Fizar
Fizar
23 Jan 2022 14:07
Hello everyone, I recently purchased an Ikea Pax wardrobe with glass fronts and am now facing the challenge of how to clean the glass surfaces most effectively without leaving streaks or scratches. I’m particularly interested in which cleaning products work best and what methods you would recommend to maintain both the shine and protect the delicate surface. There are many different tips out there: glass cleaner, vinegar water, microfiber cloth, or special care products? Are there any specific tricks for stubborn fingerprints or dust that is hard to remove? I look forward to hearing your experiences and recommendations!
hauklo
23 Jan 2022 14:43
For cleaning the Ikea PAX glass surfaces, I recommend a clear and structured approach:
- Avoid aggressive or abrasive cleaning agents that can leave the surface dull or scratched.
- Instead, use a mild glass cleaner or a solution of lukewarm water with a small amount of vinegar (about 1:10 dilution).
- Use a clean microfiber cloth, as it is lint-free and preserves the shine.
- Wipe the surfaces in smooth, circular motions to prevent streaks.
- For stubborn fingerprints or grease stains, a slightly dampened microfiber cloth with a little dish soap can help, followed by wiping again with the glass cleaner.
As a general rule: do not scrub aggressively and avoid paper products, as these can cause fine scratches.
kulau
23 Jan 2022 15:29
To address the details of cleaning the glass surfaces of Ikea PAX, it is important to first consider the type of glass surface: usually, it is standard float glass with a smooth, coated back that protects the glass front. Accordingly, the surface is quite durable, but the coating can be damaged by harsh or abrasive cleaning agents. The optimal procedure is as follows: 1. Pre-cleaning: Dust and coarse dirt should be removed before wet cleaning. A soft, dry microfiber cloth is recommended for gently wiping the surface. 2. Main cleaning: Prepare a mixture in a spray bottle of distilled water and a mild dish detergent, using about 100ml (3.4 fl oz) of water with 2–3 drops of detergent. This mildly soluble mixture removes fingerprints and grease without damaging the surface. 3. Application: Spray the cleaning solution sparingly or apply it with a slightly damp microfiber cloth, then polish it off with a dry microfiber cloth. A streak-free effect can be achieved by wiping in circular or zigzag motions. 4. Drying: Patience is important; glass should not be allowed to air dry, as this can leave water spots. The final polish prevents streaking. One more note: Household remedies like vinegar can often be effective but may damage the coating if used frequently. For very stubborn residues, it is better to use special glass cleaners designed for coated glass that are ammonia-free to ensure the longevity of the surfaces. I wonder how heavily used your glass surfaces are and how often they are touched? This could affect the cleaning frequency.
Fizar
23 Jan 2022 16:02
kulau schrieb:
I wonder how heavily they are used in your case and whether the glass surfaces are often touched? That could affect how frequently they need cleaning.
Thank you for the detailed response. In fact, the glass surfaces are used quite often in my case, especially the doors, which I open several times a day. For this reason, I am particularly concerned that frequent cleaning might eventually damage the surface. Are there any products or tools that are especially suitable for regular, everyday cleaning to save time while avoiding damage? Also, what about microfiber cloths? Some products can cause micro-scratches themselves.
karlau
23 Jan 2022 17:18
Fizar schrieb:
Are there products or tools that are particularly suitable for frequent everyday cleaning to save time and avoid damage?
First of all: The market is full of miracle products that claim to remove even stubborn fingerprints in no time—but let’s be honest, most of that is marketing. For daily cleaning, you actually don’t need much: a good microfiber cloth (and I mean a truly high-quality one—you can tell because it doesn’t shed lint after multiple washes) and lukewarm water. The more often you clean, the less aggressive the method should be. My provocative argument: If glass surfaces need to be perfectly spotless all the time, frequent use of chemical cleaners will eventually annoy you by dulling the surface. It’s better to wipe regularly with just a little water and, if necessary, occasionally use diluted dish soap. But please avoid all-purpose cleaners or abrasive products—they do more harm than good.
One more thing: In my opinion, fear of micro-scratches is exaggerated in this case. Glass is harder than many think and requires strong mechanical force or fine-grained dirt for scratches to remain visible. Just make sure to use really soft cloths and no paper!
Mufato
24 Jan 2022 09:04
Simple everyday recommendation: Use a soft, slightly damp microfiber cloth without any cleaning agents to remove dust and fingerprints. For slightly heavier dirt, add a few drops of mild dish soap to the water, clean, and then wipe dry with a cloth. Do not use ammonia-based glass cleaner, as it can damage the coatings.
